Question about Snap-On Tools & Hardware - Others
Size staples for 692175 - Snap-On Tools & Hardware - Others
What.size staples needed for arrow fastener ct50
Product description
Product description
2750-1378 Features: -Revolutionary design with ergonomic handling.-Easy release drop in loading channel for staples.-Battery contains an easy to read LED charge meter.-Built-in safety switch prevents accidental firing.-Adjustable staple drive with depth of drive dial.-Light weight design for prolonged stapling tasks.-Can use T50 type 1/4'' staples (2750-0719), T50 type 5/4'' Monel staples, T50 type 5/16'' staples, T50 type 5/16'' Monel staples, T50 type 3/8'' staples, T50 type 3/8'' Monel staples, T50 type 1/2'' staples, T50 1/2'' Monel staples, T50 type 9/16''.-staples, and T50 type 17/32'' Ceiltile staples. Includes: -Kit includes case, charger, and tool. Specifications: -10.8 volts.
staples needed for arrow fastener ct50 Google Search
Jan 11, 2018 | Arrow Tools & Hardware - Others
Staples not moving forward
You may have the wrong size staples. There are very tiny differences between different staples (T50 vs. T26, for example), and some "wrong" staples will go into your gun but be just slightly too tight to cycle properly. The correct staple number(s) should be stamped somewhere on your stapler.
Oct 23, 2017 | Staples Tools & Hardware - Others
What size staples fit this gun do yoju know any suppliers in scotland??thank you in advance
On the side of the staple gun, normally on the chrome shinny part, there is a number like 24/6. This tells you what size staple you need to purchase. look for the same number on the box in the shop. If its not exactly it wont work.
Feb 09, 2017 | Staples Tools & Hardware - Others
The 1/4" staples i bought are too large (?) For my new TR110. Am i doing something wrong or do i need to buy a smaller size?
You are probably buying the wrong staples for your unit. Check the instructions for the type of staples it uses or make sure the staple package states they are compatible with your unit..
Jan 06, 2017 | Tools & Hardware - Others
Where sells staples for work zone staple gun 8.11.3 x 1.2 mm
any office store, stationery supplier, most hardware stores will have selection and supply of staples, if you do not know what size - grab the gun and go with it to the hardware store...
Feb 06, 2015 | Staples Tools & Hardware - Others
What kind staples p300 stapler brad nailer
Staple Size 3/8 in. Crown Width, 1/4, 5/16, 3/8, 1/2, 17/32, 9/16 in. length
Brad Size 18 gauge, 3/4, 1, 1-1/4 in. length
Magazine capacity 100 staple/brad
These are sold at Lowes and other lumber centers.
Oct 14, 2011 | Ryobi P300 One+ Stapler Brad Nailer
What size staples do the 9.6v craftsman cordless staplers use?
Your staple requirements will be noted on the gun shoe ( staple magazine). Usually guns of this size take T-50 staples. Good luck with your projects
Apr 11, 2011 | Tools & Hardware - Others
What size staples and what size Arrow stapler do I need to stable coaxial cable
I would use 1/2 inch or larger. Set the staple into the wood and then pull gently to see if it holds.
Jan 06, 2011 | Arrow T50P ARROW STAPLE GUN
What size staples does the B&G Powershot staple gun use? I bought a refill pack 3/8" & 5/16" long. They fit but the shank when pulled out and loaded with staples won't close. Thank you. Julia Carr
Hi Julia,
You have the right size staples. The problem is the length of the refills. Some staplers can't accommodate a full length clip.
Break the staple refill clip in half, then insert it. The shank will be able to close and latch that way.
Best regards
Mike
Dec 06, 2009 | Black & Decker 5700 Powershot Forward...
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Tools & Hardware - Others Logo
294 people viewed this question
Top Snap-On Tools & Hardware - Others Experts
john h
Are you a Snap-On Tool and Hardware - Other Expert? Answer questions, earn points and help others
