Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
WINDOWS 7 DOES NOT RECOGNIZA DRIVE - LaCie Design by F. A. Porsche 160 GB Hard Drive
Reset windows 7 password hp
You may try the below steps to reset or recover the windows login password:
1) Insert either your Windows 7 installation DVD, or a Windows 7 System Repair disc, into your optical drive and then restart your computer. If you have either on a flash drive, that'll work too.
Note: If you don't have original Windows 7 media and never got around to making a system repair disc, don't worry. As long as you have access to any other Windows 7 computer (another in your home or a friend's will work fine), you can burn a system repair disc for free.
2) After your computer boots from the disc or flash drive, click Next on the screen with your language and keyboard choices.
Tip: Don't see this screen or do you see your typical Windows 7 logon screen? Chances are good that your computer booted from your hard drive (like it normally does) instead of from the disc or flash drive you inserted, which is what you want. See the appropriate link in the tip from Step 1 above for help.
3) Click on the Repair your computer link.
Note: If you booted with a system repair disc instead of a Windows 7 installation disc or flash drive, you won't see this link. Just move on to Step 4 below.
4) Wait while your Windows 7 installation is located on your computer.
5) Once your installation is found, take note of the drive letter found in the Locationcolumn. Most Windows 7 installations will show D: but yours may be different.
Note: While in Windows, the drive that Windows 7 is installed on is probably labeled as the C: drive. However, when booting from Windows 7 install or repair media, a hidden drive is available that usually isn't. This drive is given the first available drive letter, probably C:, leaving the next available drive letter, probably D:, for the next drive - the one with Windows 7 installed on it.
Hope this helps..
Feb 18, 2015 | HP Computers & Internet
Tip
Installing Windows 7 to ANY Netbook Using USB Drive
To copy the Windows 7 ISO file to a USB flash drive Before you begin:
  • Make sure you've already purchased and downloaded the Windows 7 ISO file to your PC.
  • Make sure you've copied any files on the USB flash drive to an external location. The Windows 7 USB/DVD Download Tool will erase any data on the USB flash drive.
  1. Click the Start button d49affd.jpg, click All Programs, click the Windows 7 USB/DVD Download Tool folder, and then click Windows 7 USB/DVD Download Tool.
  2. Under Step 1 of 4: Choose ISO file, click Browse, browse to the Windows 7 ISO file you downloaded, click it, click Open, and then click Next.
  3. Under Step 2 of 4: Choose media type, click USB device.
  4. Under Step 3 of 4: Insert USB device, click your USB flash drive in the drop-down list, and then click Begin copying.
  5. If you see a dialog box that says that there isn't enough free space on the USB flash drive, click Erase USB Device, and then click Yes.
  6. When the process is finished, click the Close button 890548ff-eff6-4f93-ba12-92692a835f86.jpg in the upper-right corner of the window.
To install Windows 7 using a USB flash drive If you don't need to start your netbook using the USB flash drive, you can simply browse to the USB flash drive, and then double-click setup.exe to begin Windows 7 installation.
To start your netbook using the USB flash drive:
  1. Turn off your netbook, insert the USB flash drive, and then restart your netbook.
  2. Press any key when prompted, and then follow the instructions that appear.
  3. On the Install Windows page, choose your language and other preferences, and then click Next.
    If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
  4. Follow the instructions to finish installing Windows 7.
on Apr 19, 2010 | Computers & Internet
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
Hi ,I have HP Pav DV6 with windows 7.But I want to install windows server 2003 & its not allowing me.I want to make it dual boot,Plzz help.I need to do it urgently...
Please understand that Windows 7 uses different startup files and procedures so it is expected that the original Windows Windows 7 system cannot be booted if you install a new dual boot Windows Server 2003 system. If you would like to install Windows Server 2003 on another partition, please do that first. After that, Windows Server 2003 will boot but WIndows 7 not. However, we can try the following method to make Windows Vista work again: Insert the Windows 7 disk into DVD-ROM. Click Start, click Accessories, right-click the command-prompt shortcut, and then click Run as Administrator. Type the following command at a command prompt and press Enter: Drive:\boot\Bootsect.exe /NT60 All In this command, Drive is the drive where the Windows 7 installation media is located. Note The boot folder for this step is on the DVD drive. 4. type the following commands at a command prompt and press Enter. Note In the commands below, Drive is the drive where Windows 7 is installed. Drive:\Windows\system32\Bcdedit /create {ntldr} /d "Windows Server 2003" Drive:\Windows\system32\Bcdedit /set {ntldr} device partition=x: (Note: x: is the drive letter for the active partition. For example, if 2003 is installed on C drive, device partition=c: ) Drive:\Windows\system32\Bcdedit /set {ntldr} path \ntldr Drive:\Windows\system32\Bcdedit /displayorder {ntldr} /addlast
5. Restart the computer.
Jun 08, 2011 | Computers & Internet
Tip
Windows 7 will always boot to drive letter C: in multiboot configurations.
When configuring a Multi-boot configuration using Windows operating systems, you need to install Windows Versions oldest to newest on separate partitions. In doing so, Windows 7 is going to be installed to Drive D: or E: or such. In all previous versions of Windows, if you have a multi-boot configuration, the drive letter for that OS is always the same as the drive where it was installed.
Windows 7 does things a bit differently. EXAMPLE: I have 3 partitions on my hard drive. C:, D: and E:. XP on C: Vista on D: Windows 7 on E: When I boot to XP, the boot drive letter is C: When I boot to Vista, the boot drive letter is D: (Simple) Well, I learned the hard way that when you boot to Windows 7 from a partition other than C:, it will show the boot drive as C: in Windows 7 (It swaps drive letters with the boot drive and C: transparently). When you boot to the other partitons, the drive letters are as they should be and the change is only effective while booted to the Windows 7 Partition.
on Dec 03, 2009 | Computers & Internet
I have a windows 7 ultimate, but i want to change it to windows xp service pack 2. can i change windows 7 to win xp without damaging all the data i have stored?
YES BUT FIRST YOU HAVE TO WIPE THE HARD DRIVE. YOU CANNOT "DOWNGRADE" FROM 7 TO XP...ONLY UPGRADE.
BACK UP ALL DATA FIRST
Oct 15, 2010 | Microsoft Computers & Internet
Im trying to connect my web cam and my computer doesnt recogniza it and I dont have the original software
THe software can be downloaded from here:-
http://www.logitech.com/index.cfm/435/4266&hub=1&cl=in,en?WT.z_sp=Image
Apr 11, 2010 | Logitech QuickCam Connect Webcam
DVD drive Read problem in my Dell Dimension 3000
Make sure you have any and all Windows 7 updates from Microsoft, along with any updates for your DVD drive for use with Windows 7. Some components work fine using Vista SP2 drivers, but some will need an update to work with Windows 7.
This Microsoft site might help verify if your DVD drive is compatible with Windows 7:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Feb 12, 2010 | Dell Dimension 3000 PC Desktop
I can't access my drive, even though all my tests say it's fine.
Right click on my computer and click manage then click on disk management. Find your drive and give it a drive letter. It probably just needs a drive letter so you can recognize it in my computer,,,Good Luck and let me know if this works...Darren
Oct 11, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
