Question about Kitchen Ranges
Stoves cooker 1100 dfadl . broken oven door,
Bottom left glass oven door shattered . need a new one.
IFIXALL
  • 868 Answers
SOURCE: Door glass shattered 3 hours after cooking
The problem is that the holding screws that secure the glass in place were most likely OVER TIGHTENED.All the screws around the support holders of the glass have to be tightened just right and the glass can cool off without the pressure that makes it pop.
Posted on May 18, 2008
MNTECH
  • 1543 Answers
SOURCE: Replacement of glass top
Check your warranty in the back of your use and care book. If the unit was manufactured prior to 1/1/06 it may have a five year part (not labor) warranty as long as you did not physically abuse it. The glass top comes as an assembled top (glass, the black seal, and the metal frame holding it)
Disconnect power. remove screws under the front edge of cook top. lift cook top and remove crossbars holding burners up against glass top. Unhook cook top / frame assemble. Install new top in reverse order.
Posted on Aug 31, 2008
BNewberry
  • 93 Answers
SOURCE: broken inner glass door
NO,  I would not recommend this at all.  However, I have seen the stoves used without one of the inner glasses with no problems.   I am a factory servicer for frigidaire and have seen people use these with one of the glasses broken and haven't seen a problem yet. But again, it's not recommended. www.applianceoutletservice.com
Posted on Nov 05, 2008
MNTECH
  • 1543 Answers
SOURCE: GE OVEN/RANGE INSIDE GLASS ON DOOR SHATTERED.
You will need a window pack, part number WB56T10152 which is not hard to replace. You should be able to order it right from GE, or an appliance repair firm can get it for you, often without extra shipping if they can combine it with other parts they need to order. Should set you back just over $100. You can remove your oven door to make it easier to work on. Use a little screwdriver to pull down the little square hole you will see on the top of the hinge opening on the frame of the oven on each side. That little metal part will lock the hinge open. Next, lift on the door and pull it toward you. The hinge actually stays with the door and lifts right out of the rectangular opening in the oven frame. Reverse procedure to reinstall repaired door.
Posted on Nov 29, 2008
outre61
SOURCE: my oven door shattered. i
This job is best done by two people, one to hold the glass in place, and the other to operate the screwdriver and position the handle and trim pieces.
The glass is held in place by the handle assembly at the top and a metal track at the bottom.  You remove the glass by removing the handle. Open the door part way until you have access to the back of the door.  The door handle is held in place by two screws on the back (the oven side).  Remove the screws, taking care to hold the handle in place.  Be sure to brace the glass, then slowly move the handle away from the door frame.  Remove the glass.  The side trim pieces will probably fall away from the door frame, although they will probably not fall all the way out.  My advice is to carefully remove them.  Be careful; they have tabs on the bottom edge that hold them in the door frame and these tabs are easily broken.  If yours are still in one piece you might just reuse them.
Remove the old glass panel and clear the bottom track of any debris.  Put the new glass panel in, beginning with the bottom track.  Set the oven handle on the top edge of the glass panel; there are tracks on the back of the handle assembly the top edge of the glass fits into.  Bring the handle toward the door frame, taking care not to let the glass panel slip out of the tracks.   The door handle has two collars that go through holes in the door frame.  Once you've got the collars through these holes, you can put the two screws back in that secure the handle to the door.
Take one of the side trim pieces.  Each trim piece has a narrow edge and a wide edge (like a capital "L"), The narrow edge faces the front and the wide edge faces the side of the door.  Each piece has a corner edge with a little tab sticking out.  These face down.  The opposite end of the trim piece has recessed edges. These slide under the edge of the door handle.  You want to insert this end first, then work your way along the length of the trim piece pushing the narrow edge between the door frame and the glass panel.
Here's the tricky part.  To get the bottom in, the best thing to do is to open (or better yet remove altogether) the drawer beneath the oven to gain access to the screws that hold the bottom track of the glass panel to the door.  Loosen the screw that holds the track in on the same side as the trim piece you're working on; the screws are on the bottom of the track about 1 inch in from the edge. Loosen the screw slightly and pull down on that edge of the trim as you push the trim piece in behind the glass.  Repeat until the trim piece tab slips through the hole for it on the track.  Tighten the screw back in place.
Repeat this process for the other trim piece. If you're patient and gentle, it shouldn't be too difficult.  I just did this myself today (2/7/09).
Good luck.
Posted on Feb 07, 2009
I have had this cooker since Nov 2013 while cooking sausages 01.02.15 the oven door shattered. I believe this is a design fault
Be careful with glass oven doors, common problem with shattering glass doors is hanging a wet/damp towel on the handle ( as this is the best place for them to dry!) When the oven is hot! . glass is not able to handle such a extreme change in tempetures. Hope this may have answered what could of happened
Feb 06, 2015 | Ovens
I have stoves es 550 new home cooker and have broken glass on outside of oven door can l get a replacement door and if so where.
Try a company called INTERSPARES
01526 322540. they will need model & serial no.
they also have a web site and are reasonably priced.
I have just used them for a glass hob lid for my cooker
Feb 02, 2015 | Stoves Kitchen Ranges
The glass shattered on my Favorit BOA 099 oven door but apparently it`s discontinued ? Where do I source a new glass / door from ?
Only a suggestion. but a good glass company could make one for you jst take the door off the stove and take it to them. tempered safety glass can be cut to fit .
Jan 20, 2015 | Ovens
NEED PARKINSON COWAN - OVEN DOOR - GREEN -
Need replacement glass grill door-outer for my Parkinson Cowan Cooker No. OVA60TCGRN
Looked on all available spare parts sites and found it on none of them.
I sooo wish I had not found time to take it apart to clean!
Jun 30, 2010 | Parkinson Cowan SG320 Gas Kitchen Range
The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Jan 24, 2010 | Zanussi Ovens
GE Gas Built-in Oven model JGRP17B Door Replacement
pull out the bottom drawer you will find a plate on the left side pillar of the drawer opening the model # and, serial # is there this is all that is needed to order a new door glass
Apr 21, 2009 | Ovens
Outer oven window shattered
sure should be replacable, youo can cll the manufacture for a replacemnt glass, most only held in by a feww screws, cant see it being the end all for you oven
Dec 22, 2008 | Kitchen Ranges
Kitchen Ranges Logo
13 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
