Question about Home Security
Reset combination dial lock - Home Security
3 Suggested Answers
  • 38 Answers
SOURCE: How to reset EasyGo Travel Sentry 3-Dial Combo
well.maybe you should get a new lock because there is nothing to do with it
Posted on Sep 15, 2009
SOURCE: how do I reset a
Hello sstacy1,
You can follow the steps below to fix your problem on how to reset your 4 dial Samsonite combination lock:
  1. Set the dials to 0-0-0. Find the lever or button next to the dials.
  2. 2If your lock has a lever, lower it and turn the dials to the desired numbers. Return the lever to its starting position.
  3. 3For locks with a button, push the button towards the dials and turn them to the desired numbers. Release the button.
  4. 4The lock is now set to the new combination.
Read more: How to Reset Samsonite Luggage Combination Locks ' eHow.comhttp://www.ehow.com/how_4761466_reset-samsonite-luggage-combination-locks.html#ixzz157Q4Ap
Hopefully it helps.
Thank you for using fixya
Posted on Sep 10, 2011
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
How do I can unlock dial lock
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock. 25284217-gdc3ufgmlwaqnv2deqjxyac2-5-0.jpg With the Combination Step 1 Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
With the Combination Step 2 Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
With the Combination Step 3 Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Forgotten Combination Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Forgotten Combination Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination Step 1 Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Resetting Your Combination Step 2 Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Resetting Your Combination Step 3 Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Resetting Your Combination Step 4 Roll the dials until you have your new combination.
Resetting Your Combination Step 5 Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links
Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals!
www.alibaba.com $0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now!
www.hostgator.com/1Penny Rooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now!
www.airconditionings.cn Download Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now!
www.facebook.com by Taboola
Sponsored Links
Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft Recipes See Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR
Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
  • Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
  • Do not open a lock that does not belong to you. It is against the law.
REFERENCES
RESOURCES
ABOUT THE AUTHOR Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
  • Creatas/Creatas/Getty images
Suggest an Article Correction
How to Open a Combination Lock on a Samsonite Suitcase
  • How to Reset the Combination on an American Tourister
  • Airline Rules on Locked Luggage
  • How to Reset a TSA Lock
  • Reagan Airport & Luggage Storage
  • How to Prevent Lost Luggage
  • Cost of Shipping Luggage Ahead to Destination
  • How to Repair Wheels on Luggage
  • The Odds of Losing Luggage
  • How to Make Inexpensive Luggage Tags
  • Solutions to Lost Luggage in Air Travel
  • How to Measure Luggage
  • How to Expedite Lost Luggage Claims
  • What Are the Dimensions of Hand Luggage for Air France?
  • What Rights Do I Have If My Luggage Is Lost?
  • How to Store Luggage While Traveling in Italy
  • pixel.gifHappy Camper: Test Your Outdoors Knowledge
  • pixel.gifCruisin' Along the PCH: Test Your Knowledge
  • pixel.gifWhich U.S. Landmark Would You Be?
  • pixel.gifCan You Pass for a Proper Brit?
  • Nov 15, 2014 | Lands Phones
    How to reset combination
    To set a new combination:
    The initial combination is set at the
    factory to 0-0-0-0
    1. Open the compartment door
    2. Push the reset lever left and down.
    The lever remains in this position
    3. Rotate dials to your desired combination
    4. Push the reset lever, up and right, back
    to the original position
    5. Close the key storage compartment door
    6. Scramble the combination dials to lock
    the door and conceal your combination
    7. Close the shutter door
    Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
    How reset combination lock
    1. Open the lock with the factory preset combination of 0005.
    2. Find the tab on the end of the part of the locking mechanism that has the numbers.
    Combination Reset Tab
    3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
    4. Change the combination to the desired combination.
    5. Flip the tab back down. The dials are now re-engaged with the tumblers.
    Aug 13, 2014 | OnGuard Doberman Series Lock 8030
    How do I reset a 4 dial Samsonite combination lock
    Hello sstacy1,
    Hopefully it helps.
    Sep 08, 2011 | Health & Beauty
    Resetting a kipling 3 digit lock
    In order to set or re-set your Kipling lock, please follow these steps.
    Step 1
    Turn the dials to the preset combination and align the numbers to the Guide Line.
    Step 2
    Push the reset button with a pen (or other tools) all the way until complete turning the dials to your desired combination. (Do not let go of the button while setting the dials)
    Step 3
    Release the Reset Button after changing to your own combination. Your lock is now ready to open at its new combination
    Jul 28, 2011 | Garden
    How to reset the combination, GE Hide a Key Storage Lock Box (GE Access Point Series)
    Step 1. With the cap closed, set the numbered dials to the combination line. The factory preset combination is "000".
    Step 2. While maintaining the combination in place, rotate the "RESET" dial indicator beneath the letters approximately 90 degrees to line-up with the combination line. If the correct combination is not set, the "RESET" dial will not rotate.
    Note: Using excessive force can damage the dials.
    Step 3. Set the new combination while maintaining the position of the "RESET" dial.
    Step 4. While maintaining the combination in place, rotate the "RESET" dial back to the original position. The combination has been changed.
    Sep 07, 2010 | GE Home Security
    How to set Samsonite combination lock
    Step 1:
    Step 2:
    Step 3:
    Try that :)
    Sep 26, 2009 | Kwikset Locks & Locksmithing
    I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
    Instructions:
    Opening the key storage
    compartment door
    1. Open shutter door to reveal the dials
    and the release button
    2. Rotate dials to the current combination
    (if the lock is new, the combination is set
    at the factory to 0-0-0-0)
    3. Press down on the release button
    to open the door
    4. Pull the door fully open
    5. Add or remove keys
    6. Close compartment door
    7. Scramble the combination dials to lock
    the door and conceal your combination (A)
    8. Close the shutter door (B)
    factory to 0-0-0-0
    (see instructions above)
    7. Close the shutter door (B)
    To hang shackle model
    2. Push the shackle release lever to the left
    to open shackle
    3. Pull the shackle up and out of the lock
    4. Place shackle around door knob or other object
    5. Close shackle to lock
    6. Close the compartment door
    Reminder:
    (A) The release button will open the lock
    until you scramble the dials
    (B) Keep the shutter door closed to increase
    weather resistance and to conceal the
    dials from view
    Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
    Home Security Logo
    158 people viewed this question
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
