Question about Foxconn 945P7AA-8KS2 Motherboard
Ethernet controller driver - Foxconn 945P7AA-8KS2 Motherboard
Not detect ethernet controller for dell optiplex 210L i looking for the driver
You want to try and see if there is a driver update for the ethernet controller. Go to: START> RIGHT CLICK "MY COMPUTER"> then PROPERTIES> DEVICE MANAGER> NETWORKING> ETHERNET PORT. You can roll-back the driver or you can try to update the ethernet driver using Windows Update Program. Make sure the driver is located in the device manager system and windows recognizes it. Your Ethernet Controller is a discontinued product. If you can't seem to get the ethernet controller to work and don't have the Floppy Disk Driver for it, then I suggest replacing it with a new stand alone ethernet controller that uses PCI or PCI-E ports. You can find some at Best Buy and Staples. They are easy to install and they don't use your motherboard memory and are not integrated on motherboard. I hope you find something that works and you can get back online again.
Jul 22, 2011 | Computers & Internet
No ethernet controller
> no Ethernet controller
Does your motherboard have a built-in Ethernet controller?
Are the correct device-drivers loaded, so that Windows can use that controller?
Do you have an add-in Ethernet adapter connected to a PCI slot on the motherboard?
Jun 26, 2011 | Computers & Internet
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
May 09, 2010 | ASUS P4P800 SE (890552603657) Motherboard
How i istall ethernet driver from internet
If you have no internet because the ethernet controller was not installed, you will need to download the ethernet drivers from another computer.
To do this, you will need either the motherboard model or the ethernet controller model. Search google for your motherboard model, and then on the drivers page, find "LAN drivers". Download the drivers, save them to a usb and transfer and install them to your pc.
Feb 01, 2010 | Broadcom BCM5721 NetXtreme Ethernet...
I like to download ethernet controller driver but not from driver detective as this require an internet connection to complete what i want to do.
you nedd to go to a website and download an updated ethernet controller driver are useless because you can't even access the internet without the ethernet controller, unless you have a second PC already hooked up to work with the internet, then make a copy of the ethernet driver, and then copy it onto the original PC to get it acces the intenet. Most people may have to go to a computer repair store and ask if they can buy the ethernet controller driver for their OS and PC on a CD or flashdrive, or instead, but an external Ehternet controller device and connect it to your PC via USB.
Jun 19, 2009 | Compuware DriverStudio (dd-rstd-np/nm31)...
Ethernet controller has a yellow ! makr after it
reinstall the ethernet adapter driver from the dell drivers and utilities and extract the necessary ethernet driver under network driver
Apr 04, 2009 | Dell Latitude C610 Notebook
Pleas i m not getting the ethernet controller
You need to re-install your Ethernet driver.If you have Driver CD with you then first uninstall the Ethernet driver from device manager and install the Ethernet driver from you driver CD.
If you don't have driver CD with you then You can download ethernet driver by Clicking here.
Thanks
Mar 04, 2009 | HP Compaq nx6115 Notebook
Ethernet Network controller
use driver updating software ie driver magician. it scans ur outdated drivers and automatically downloads drivers that r compatible for your computer.............
Dec 25, 2008 | Compaq Presario 700 470024-192 Notebook
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Sep 02, 2007 | Dell Dimension 4600 PC Desktop
Foxconn 945P7AA-8KS2 Motherboard Logo
19 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
