Question about Eljer Home
Eljer whirlpool electric switch - Eljer Home
Where can I get a replacement ring for around the on/off switch
rom plumber whole sale shops, pool or spa shops
take your s along as a sample or take a photo of where it goes and dimensions
May 07, 2016 | Eljer Laguna Six Jet Whirlpool
Where does the hose on the on off switch on whirlpool madison is the model go to. It came unhooked and dont
There should be a control box on or near the pump motor. Look for a small hose connection on the control and attach hose there.
Hope this helps.
Bob
May 01, 2014 | Eljer Madison Eight Jet Whirlpool
Need reviews on Eljer Whirlpool Triangle Tubs. Eljer a Good Tub to Buy?
Eljer is owned by Jacuzzi Whirlpool. Very nice tub. Eljer is one of the bigger Bathtub Mfg out there.
Not sure why he has not heard of them. Lowes is probably the biggest seller of that brand.
Rod
US Parts Center
Feb 07, 2013 | Eljer Triangle WP 60x60 LH 10JT
Eljer in line heater came with a small copper coil but no instructions as to where it goes or how to install.
that small copper wire is a ground wire that goes from the lug on the heater to a water pipe. attach that wire to the pipe to ground your heater.
Dec 16, 2010 | Eljer Whirlpool In-Line Heater-...
Eljer jetted tub on and off switch will not work
It may seem like a dumb answer but check the ground fault outlet or breaker. Then make sure there is enough water in the tub. It should be a few inches over the jets.
Mar 23, 2010 | Eljer Home
Installing whirlpool tub
If it is a five foot tub, home depot usually carries them, if not any plumbing supply store will have them.
Jun 22, 2009 | Eljer Home
Jets not working
i have seen this in the past, a ground fault electrical outlet on the inside of a roman tub,if you have a 2 story house look for access panel on or by tub. otherwise you have to remove tile or other to access motor, you probably need a step too anyways
Mar 12, 2009 | Eljer San Antonio Acrylic Whirlpool -...
Home Logo
27 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
