Question about HP OfficeJet 6110 All-In-One InkJet Printer
Can't stop asking to be aligned
After switching between foto cartridge and color one, printer can't stop asking to be aligned, what to do?
  • 91 Answers
Here are your solution options..you may have to right click on link to open it...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00657&lc=en&dlc=en&cc=us&product=75152
Posted on May 21, 2009
After replacing 901 black cartridge printer keeps saying aligning cartridges please wait
every time replacing an ink cartridge, printers asking for alignment.do it once , following instuctions which appears in printers monitor.after,look at printed page and saw if is asking to scan once this page.
Feb 15, 2015 | HP Officejet 4500 All-in-One -...
Ican't align print cartridges .I change the color cartridge (57) and now when i start the printer i receive a message "Press OK to print Allign page" . The printer start the operation and...
Your color cartridge does n't print well
in order to have a success alignement
check if the expire date has pass
you need to replace the color cartridge or refill it
by this easy method
Jan 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
My HP Officejet 4500 keeps telling my to align my printer cartridges and I have done it several times. After I align them and print something it requires me to align them again.
Try removing the cartridges, closing the printer, and disconnect the power. Let sit for at least 10 minutes, then hook up the power, wait until it stops making noises, the reinstall the cartridges, black first, then color, and if the alignment comes up again, press cancel. This should remove the error.
Sep 30, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Using only the black cartridge
go to the control panel on the maintenance, configure the cartridge used, change to "black cartridge only"
May 30, 2009 | HP PSC 950 All-In-One InkJet Printer
ASKING INSTALL COLOR CARTRIDGE
Check if the cartridge was inserted correctly (right slot) (remove it and insert it again)
Check if the cartridge is original and the sticker was removed. Turn off your computer, and your printer. Start up your computer and after your printer. Try again.
If the problem continues, insert the old one cartridge (which was removed before) and see what happen...
If stop asking for install color cartridge, you have failure on your new cartridge
and need to be replaced.
Sep 24, 2008 | HP DesignJet 750c plus InkJet Printer
In starting 1 page print
I believe that after changing the ink cartridge you havent completed the alignment process.This Alignment test page will print everytime you turn the printer ON.To Complete the alignment follow my steps.
1.After turning the printer ON, wait untill the printer prints the Alignment test page.
2.Then place the alignment test paper on the scanner, facing down in a correct position.
3.Then press the Scan button(color) and wait untill the printer ON light stops flashing.
4.After the light stops flashing, take the paper out and the alignment process is completed.
Turn OFF and turn On the printer, it will not print the Test page again.try it and please let me know.Would really appreciate your rating for my solution.
Thanks
Riz.
Apr 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    2. Disconnect the USB cable from the all-in-one.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
    5. Reconnect the USB cable.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
61 people viewed this question
Seeker5211
Seeker5211
