Question about GE Refrigerators
Door won't totally close
When you slam the door shut, it still pops open.
  • 700 Answers
Try taking the front kickplkate off and then adjusting the front rollers so that the frig slightly tilts toward the back
Posted on May 21, 2009
Rear window doesn't stay locked
you need to move the latch closer together...
Nov 12, 2012 | 1996 Jeep Cherokee
Trunk won't latch closed
move the latch up slamming it knock it lower
Sep 01, 2012 | 2002 Mercury Grand Marquis
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
Dryer won't turn off
Relay stuck closed in control circuit, usually the door interlock. Slam the door shut a couple of times to see if it frees the contacts.
May 15, 2012 | Washing Machines
Hotpoint wm64s indicating door not shut program will not function cus door light flashing...however door iis shut n wont open
You have a mildly confused machine, probably the result of the fact that there is a moment where the door lock can activate, but the sensor that tells if it's shut cant because the door isn't QUITE pushed home hard enough.
First try, just give the door a whack with the heel of your hand in line with where the door catch is. It may be that simple to relocate the door and the sensor properly
Failing that, unplug at the wall and wait 20 minutes. This will, without doubt reset the machine and allow you to open it (While it is still powered off!). Open the door and shut it firmly.... I hesitate to say SLAM the door.... But slam-ish won't hurt, just don't be stupid about it!
All should be OK going forward
Jul 04, 2011 | Hotpoint WMA64 Front Load Washer
Fridgedaire Upright Freezer Door won't stay shut. Normally when closed, you hear the seal take place, now it pops open
Check the seal in the corners on the side of the door your hinges are on, ya may need to tack it down with crazy glue, but usually it'll curl in the corners preventing door from closing or pop open after you walk away
May 06, 2011 | Kitchen Ranges
I have a whirlpool gold dryer. I can't keep the dryer door shut while clothes drying. it keeps popping open.
the problem is the door latch have a look and see if the door pin (plastic) still has both prongs they should look the same from side to side if they are then the tension wires in the doors clamp have come apart. if one side of the door pin has snapped off (most common problem from slamming door closed) replace the door pin
hope this helps
please take the time to rate this repair
Aug 03, 2010 | Whirlpool Dryers
Door does not stay closed
your door clip needs to be replaced or realign
your door
Jun 11, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
Garage door slamming shut
springs are shot/wrong. door not balalnced.
Sep 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
