Epson printer problems
Printing in light blue, skips some text.
  • 4 Answers
SOURCE: Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Posted on Jan 08, 2008
ohms
  • 1879 Answers
SOURCE: epson rx 500 print problem
Please confirm that the head cleanings were done using the most effective method listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Posted on Jan 26, 2008
Inky
  • 691 Answers
SOURCE: Epson CX6600 Skips every other 5th line when printing
Run the print head cleaning routine from the printers driver or control panel. you may have to run it 3 or 4 times to regain all the lines.
Posted on Jul 16, 2008
  • 4 Answers
SOURCE: epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
Posted on Feb 20, 2009
SOURCE: Epson TM-U220D Receipt Printing Problem
mau download driver epson tm-u220d ga ada...
klo mau cari dimana yah
Posted on May 11, 2009
Print badly, skip lines and blurry quality at some place
There is in built up on the bottom of the head. There is several spots along the print heads path that build up ink. Clean the path as much as possible. The is also a cleaning blade ( acts as a windshield wiper) near where the head parks. Make sure its clean. If this doesnt solve, you will need to see a professional.
Apr 10, 2010 | Epson Stylus NX400 InkJet Printer
After every line of black text there is a light blue line.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 01, 2010 | Epson Stylus CX3200 All-In-One InkJet...
My epson stylus photo R240 skips black lines when printing even though I have clean the print heads 10 times .
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, skip lines, put stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
Feb 01, 2010 | Epson Office Equipment & Supplies
The blue colour has run out but the black is fresh and it won't let me print a black text document-is it possible with out having to go and get a blue cartridge?
The Epson DX4850 will print black only. You can find a check box in the settings to Print Black only in the advanced options.
This works fine for me when all my colours are empty.
Jan 18, 2010 | Epson Stylus DX4850 All-In-One InkJet...
Epson r390 printer prints blank(no text on paper)
check that there are drivers installed for the printers
Jun 24, 2017 | Epson Stylus Photo R390 InkJet Printer
May 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
376 people viewed this question
k24674
