Question about Janome Sewing Machines
Replacing bulb on janome 2030qdc
Bulb burnt out
How do change a janome 4000 light bulb
Consult your owner's manual. Some newer machines require a technician to replace the bulbs--inconvenient, but that's the way it is.
Perhaps this will help:
http://www.fixya.com/support/t553096-replacing_light_bulb_mc4000
Dec 27, 2015 | Janome Sewing Machines
How do I change the light bulb on a janome sewing machine js1004
right down front there,s a little screw for replacing bulb caution unplugg it from ac
Sep 16, 2015 | Janome Sewing Machines
Can I replace an ordinary light bulb in my Janome machines with a LED bulb?
as far as bulbs they will work fine IF you ever find the proper ones, size wise .
May 05, 2015 | Janome Sewing Machines
HOW DO i REPLACE THE BULB IN MY JANOME J3 18?
sometimes there are hidden screws,, look for a plastic circle that you can lift gently with a small screw driver
Apr 19, 2015 | Janome Sewing Machines
Where is the light bulb located on a Memory Craft 4000 sewing machine. Need to change light
Hi Rhonda I have a 9000 and a 500e and the light should be directly above the needle shaft.
Good luck
Jan 20, 2015 | Janome Sewing Machines
How do i change the lightbulb on my Janome 6019 sewing machine?
On most sewing machines the light bulb is located inside the faceplate on the left hand side of your machine.
http://www.janome.com/documents/File/ManualFile/6019QC.pdf
The faceplate is part number 17 in this manual.
One that has been removed, the bulb should be visible. You will need to look at the old bulb to see if it a screw type or a bayonet type, in order to replace it with a new one.
If this is not correct try the Janome website for advice, they have a forum and an ask Jan section for problems etc.
http://www.janome.com/index.cfm/LearningCenter/AskJan
http://www.janome.com/fusetalk/forum/
I hope this is helpful to you!
Sep 17, 2010 | Janome 6019QC Mechanical Sewing Machine
I have a Janome 5700, the light has burnt out and there is no directions in manual for changing it, I also cannot find the burnt out light. Can you help. Thanks Penny
Most sewing machine lamps are located inside the face cover on the left hand side of your machine. It should pull open as it is hinged at the back and clicks into place when you close it. The lamp will be visible to you when you open your machine. It will either need a bayonet or screw type bulb replacement. You will need to look at the broken bulb in order to see what type your machine needs.
http://www.janome.com/documents/File/ManualFile/MC5200.pdf
If you look at page 4 of this manual, which is similar to your machine, you will see the face cover is part number 11. In the smaller picture below you can make out the hinge on the back of the machine that allows you to open the face cover like a door. Hope this helps!
Sep 03, 2010 | Janome Memory Craft 5700
Screen dull on Janome mc 8000
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light
Janome Memory Craft 8000 LCD Backlight Replacement Kit
Mar 26, 2010 | Janome Memory Craft 5700
How do I replace the light bulb on the Janome MC9000?
I HAVE A SEWING MACHINE CRAFT6000 BUT THE LIGHT IS NOT WORKING BOUGHT NEW BULB STILL NOT WORKING HELP PLEASE!!!!
Nov 13, 2009 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
18 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
