Question about Tablets & eReaders
Administrator login - Tablets & eReaders
Administrator login
When installing your printers drivers, right click on the disk, or file and click "run as admin"
May do the trick.
Jan 13, 2014 | Tablets & eReaders
I forgot password
If you can tell me what the Os do you use, it could be must better.
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password reset tool. I recommend Windows Password Reset.
Resource: http://www.windowspasswordreset.net
Jul 29, 2012 | PANDIGITAL 7270FW Tablet
How to unlock the administrator password
Use windows password reset tool is the best way to recover admin password
Here are three tools for you.
Windows Password Reset( http://www.windowspasswordreset.net )
Windows Password Recovery Tool ( http://www.windowspasswordsrecovery.com )
Windows Password Crack( http://www.windowspasswordcracker.com )
Jul 19, 2012 | eMachines eM250-1162 Atom N270 1.6GHz 1GB...
Forgot windows login password
Hi, there. This all-in-one password recovery software will surely help you out. It is capable of resetting forgotten Windows Administrator login password, and recovering lost password for multiple web browsers, mail clients, FTP clients, chat messengers etc. Next time better make a password recovery CD and put it in safe place. best regards.
Jun 29, 2011 | Fujitsu LIFEBOOK P1510D Tablet PC
How do i login on as administrator on my computer?
Login With the Administrator Account in Windows XP Professional
Click the "Start" menu and then click "Log Off."
Click "Switch User" when the prompt screen opens.
Press "Ctrl," "Alt" and "Delete."
Click on "Administrator" when the "Log on to Windows" screen pops up. Type in the administrator password, if applicable.
Click "OK." You will now be logged in as the administrator.
Log On as An Administrator in Windows Vista
Start your computer and allow it to continue through its startup process. By default your computer will simply load directly to the primary user account (usually the administrator account), but if there are multiple users on the system it will load to the account login screen.
Use the mouse to click on the administrator account from the list of available accounts to log on. This step is only necessary if you've customized Windows Vista with more than one account or you have set the operating system to load the login screen first.
Enter the password required in the password field to log on to the administrator account.
Click the "OK" or "Log On" button once you have entered the password. This button may be labeled differently depending on the version of Windows Vista or any GUI (graphical user interface) changes you may have made.
Log on as an administrator from within the Windows Vista environment by clicking on "Start" and then "Log Off." As soon as you have logged off, you will be returned to the login screen where you can choose the administrator account from the available list.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Compaq tc4200 Tablet PC
I want to install my toshiba tecra stylus driver
if u need driver for it then u can get it free from www.freedrivers.com after geting the set up easily click on setup and follow the instructions shown on screen. if u get problem then u must login as administrator and then do setup again
Mar 03, 2009 | Toshiba Tecra M4-S435 Tablet PC
Forgot password -samsung q1 ultra
Have You Lost Your Windows Admin Password?
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press <ctrl>+<alt>+<del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Jan 01, 2009 | Samsung Q1 Ultra Tablet PC
Window will not reboot after
try leave the password blank.
you know? When we install Windows, it automatically creates an account “Administrator” and sets its password to blank. So try to logon as adminstrator ,here is the guide:
Start system and when you See Windows Welcome screen / Login screen, press ctrl+alt+del keys Twice and it’ll show Classic Login box. Now type “Administrator” (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from “Control Panel -> User Accounts”.
if that doesn't work,then just learn from others how to reset windows password with Windows Password Recovery Tool.
Nov 02, 2008 | Gateway M275 Tablet PC
M275
If you are unable to install the software it means that you don't have administrator rights.Its due to ntfs permission ,you must install it with login into your account as administrator..just make one more administrator account in safe mode and try whether you are able to do fix the issue or not.
Jul 21, 2008 | Gateway M275 Tablet PC
Forgot password
Forgot Windows login password? Take it easy, you can unlock forgotten password with Windows 7 Password Recovery Tool easily!
Aug 14, 2007 | Compaq D70045-236 Tablet PC
Tablets & eReaders Logo
46 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
