Question about Sony SDM-HS95P/B 19" LCD Monitor
Black screen with message about no input signal
SDM-HS95P only shows a black screen and a message that says:  No input signal. Input 1: DVI-D. Go to power save. The DVI-D cable is plugged in correctly.  Using a different monitor (NOT same model) and a VGA cable, the Sony Vaio tower boots up fine to Windows XP Media Center.
I tried plugging a VGA cable into the mother board and the HD15 port on the original SDM-HS95P monitor, but screen remains black. What is wrong with my monitor? How do I fix this problem?
  • Anonymous Mar 12, 2014
    show on the screen : imformation
    all the time
Might be something wrong with your monitor's data cable
Posted on May 21, 2009
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
Inputs quit working
check the cords for open.if not, try to wiggle just a little the cords while you insert it, if the screen flicker and shows video signal, you'll need a tech to resolder the jacks.
May 28, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
No DVi input, then computer goes to sleep
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
Detech Input message on the screen at the starting
I have the same monitor and assume you have both analog and digital inputs. In other words, both a DVI and standard analog monitor input. I noticed on mine that there was a "factory reset" on the menu. Have you tried that? What type of video card are you connecting to? DVI? Do you have any adapters or gender changers connected to it?
Let me know.
Jason
Dec 04, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
The screen will not come up but gave this message 'No input signal, go to power save
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
Oct 26, 2008 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
URGENT Big project due...Monitor won't stay on...light goes yellow after initial message c below
check the cable which connects from the monitor to cpu is connected properly... if it s not connected properly this problem occurs.. just reconnect it ... ur problem will be solved...
Dec 03, 2007 | Sony SDM-HS73P 17" LCD Monitor
No signal when connected via hdmi to dvi on tv
ya nothing shows up is all black no sound nothing
Oct 27, 2007 | Sony Playstation 3 (PS3) Console
Sony SDM-HS95P/B 19" LCD Monitor Logo
1,170 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
