Question about Refrigerators
Ice maker is overflowing, I replaced the valve and the water is still overflowing the tray
I have a frigidaire. The ice maker over flows the tray and runs into the bin. I have replaced the valve and it didn't fix the over flow. Can anyone suggest anything?
  • jp4andmore May 21, 2009
    The icemaker works, it is a filling problem.
  • jp4andmore May 22, 2009
    Shinn, please don't waste my time with your stupid comments
    Scholar:
  • 85 Answers
This is usually a problem with the icemaker. The only fix is to replace it.
Posted on May 21, 2009
  • shinn8
    shinn8 May 21, 2009
    I understand your thinking. But the icemaker controls the valve. It could be keeping valve open too long or more likely it is a problem called wicking. This is caused by sediment build-up in icemaker which causes water to leak out of icemaker when it fills. I have changed 3 icemakers in the last 2 weeks with the same problem and that fixed all of them.
  • shinn8
    shinn8 May 22, 2009
    No problem. Sorry.
The drip pan is filling up with water and then over flowing. We have to empty it once a day. Then I noticed the ice maker has stopped making ice. Any ideas?
Turn icemaker off see if water problem stops ice tray water valve may be overflowing tray cycle timer may be faulty or faulty water control valve.
Jul 31, 2015 | Whirlpool Refrigerators
Water from ice maker leaks into freezer and freezes door shut
http://www.appliancepartspros.com/frigidaire-valve-242252702-ap5671757.html
It sounds to me like the valve is not closing all the way and allowing water to flow when it should not. This overflows the tray and allows water to run to the bottom of the freezer. It could also be a timing or switch issue. IF you want to be sure replace the valve and if that does not work then replace the whole icemaker.
Jun 28, 2015 | Frigidaire Refrigerators
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
Thanks for being there. I bought a Whirpool refrid/ freezer on top from a friend and the water pump behind ans at the back of the unit was broken. I had a repair man replace the water pump. What happens is...
If your ice maker was leaking before and after the valve replacement, it is likely the ice maker that is at fault. The ice maker energizes the water solenoid, its not a pump, which then opens to allow the pressurized water flow up to the ice maker. If the valve solenoid has been replaced, the culprit is likely the ice maker itself. The valve should only be open for about 7-9 seconds, but if the ice maker motor is slow, or if there is some other malfunction with the ice maker, it will energize the valve for too long, causing it to then overflow. It could also be a hairline crack in the ice maker mold that is causing it to leak.
Oct 13, 2010 | Whirlpool Refrigerators
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Frigidaire water leaks
I suspect that when the water valve was replaced, that the plug's were reversed that provide the power to the valve. Exchange the two plugs on the water valve and you may find the problem is fixed.
May 25, 2008 | Frigidaire FRS26H5AS Side by Side...
Ice maker over flows with water
There is an orifice that controls the water flow to the ice maker . If to much water is being fed to the ice maker it will result in an overflow. You may want to check the pressure of the water system in your house.
If the overflow is being caused by a continuous feed to the ice maker your electric valve supplying the water may not be reseating after it shut off electrically. If this is your problem obtain a new valve assembly to replace it.
Apr 30, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker overflows with water
yes, in fact the icemaker does meter the amount of water delivered to the icemaker, the valve should only be energized for 7 seconds. after that the power is cut off, so if valve continues to let water flow, it's bad (might have debris from water line keeping it open. unserviceable. )
Mar 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 9550580 ice maker
try turning down water pressure or reduce flow into ice maker by turning tap partially off, this should resolve problem. Regards Advisor
Aug 23, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Refrigerators Logo
397 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
