Question about Linksys Wireless-G WRT54G Router
Wireless Network Connection is no longer connected
I own a Linksys Wireless-G WRT54G Router. It was working this morning, but now the Wireless Network Connection is no longer connected. On the front of the unit, the "Wireless G" status light will not light up. The only way to get the internet to work is if I run an ethernet cable from the router to the PC
  • Anonymous May 22, 2009
    my linksys router doesn' seem to be working...i reset it, along with the modem. The only way I am getting internet access is by unplugging the modem from the router and directly connecting to my laptop
  • Anonymous May 25, 2009
    My Problem is a little different I have this router that I use with my cable router If I run a cable from my linksys to my laptop it will indicate that it is connected but cannot go on the internet. Same with the wireless connection. If I disconnect the linksys router and cable right to the cable router I have no problems. I tried reseting power and reset the reset button i also changed the cable that linked from the linksys to the cable router with a known good one and that wasn't the problem either.
    Problem Solver:
  • 8 Answers
I've had this problem before. Simply power cycle the device (unplug it, wait 20 seconds, and plug it back in). If this starts happening often it may be nearing the end of this products lifecycle (you may need to replace it). I had mine for 3 years before I had to replace it.
Posted on May 21, 2009
We recently got a new laptop with Windows 7. The wireless connection worked for a while. But now our wireless network is no longer visible to the laptop. The only network available is named Linksys which...
Did you try to reset the router ?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Sep 12, 2010 | Linksys Wireless-G WRT54G Router
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
I have a desktop that is contected to DSL through the linksys router and it connects ok. I have two wireless laptops and neither will connect as of yesterday. When I go to network connections I see a red x...
Your router is turned off that's why it says network cable is unplugged and your wireless does not work. Check if there are lights on the front panel of the router. Make sure the power adapter is plugged in
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G wireless connection problems.
click on Start -> Control Panel -> Network Connections -> Wireless Network Connections -> Properties -> In the box in the middle scroll to and click on "Internet Protocol (TCP/IP)" -> Click Properties -> Make sure "Obtain an IP Address Automaticaly" is Ticked -> make sure "obtain dns address automatically" is Ticked. -> ok -> click ok
See if you can connect
Click on Start -> Run -> Type CMD and hit enter.
a command box will open. type in IPCONFIG/ALL
Please copy down the following numbers ---
IP Address
Subnet Mask
Default Gateway
DNS Servers
Please make sure you copy them correctly and post them here.
Dec 24, 2008 | Linksys Wireless-G Broadband Router
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Wireless connection
Possible you did reset the router. Its okay to connect to that linksys network name. But if you want to customize you network name.
MAKE SURE TO USE THE WIRED COMPUTER TO SETUP WIRELESS CONNECTION.
Example : The Desktop computer that is connected to directly to router.
Just follow the steps.
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3967&p_created=1159257209&p_sid=aNKUFggj&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODExJnBfcHJvZHM9MCZwX2NhdHM9MTcyMSwxNzIzJnBfcHY9JnBfY3Y9Mi4xNzIzJnBfc2NmX2xhbmc9MSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PUNoYW5nZSBTU0lE&p_li=&p_topview=1
Hope it will work..
Oct 14, 2008 | Linksys Wireless-G WRT54G Router
Having problems with linksys connection
Please check if the router needed IP address?
- if yes? ( goto Network Settings and add the IP address.
- if not? ( obtained you Network Settings do not input IP address.
Double check also if your Router is properly configured?
Sep 21, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Ver6
Try reconfiguring the Linksys router. Click on this link for instructions on how to configure the router with a cable Internet connection.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=4da24a60bfc84fe9ad65ce672b4b8b52_KB3686_EN_070208_v1.xml&amsstatsid=4067617
After configuring the router and if you already have an Internet connection, then connect your second computer to any numbered port of the router (port 1,2,3, or 4) and test the Internet connection.
Configure the wireless settings of the router by following the steps on this link.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=2f99c35863934424a932742692a5e83b_KB4024_EN_070329_v1.xml&amsstatsid=4067626
If you want to have a wireless security for your network, you may clck on this link for instructions.
Then try connecting your wireless computer to the name of your wireless network and enter the security key (if you have created one).
Sep 08, 2008 | Linksys Wireless-G WRT54G Router
Lost connection on laptop
I would reset the router most of those linksys will have a small hole in the back of them that say reset push it and let it go back to factory default see it that does not fix your prob
May 10, 2008 | Linksys Wireless-G WRT54G Router
Router stopped working
Try first to reset it to the factoty settings by pressing the brown button on the back of the unit, next to the Internet connection. You will have to reprogram the router with your PPPoE settings, if any, and your wireless security.
Oct 07, 2007 | Linksys Wireless-G WRT54G Router...
Linksys Wireless-G WRT54G Router Logo
265 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
