Question about Belkin (F5D7010) 802.11a, 802.11g/b Wireless Adapter
Belking F5D7010 notebook card is not connecting
I have Belking F5D6231-4 wireless DSL/Cable Gateway/Router.  Yesterday i did firmware upgrade.  After I did that there is not power indicator on. And it stoped working.  Then i downloaded lastest driver 7xxx installed still no luck. Can you please help to solve this problem
  • 70 Answers
Re: Belking F5D7010 notebook card is not connecting
Is the router having a problem or the PC card?
Posted on Oct 19, 2007
0 characters
3 Points
Other computers do not recognize my network
If you have a wireless router and it is connected to the DSLor cable modem then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jan 27, 2012 | D-Link Network & Wireless Adapters
.uki have got a belkin
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Apr 02, 2011 | Belkin 802.11g Wireless Notebook Network...
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have Belkin f5d7010 card. I cannot connect to interet with laptop. Can I download drivers for card and transfer to cd for installation on laptop. I am using Netgear router and don't know which driver to...
you can download drivers from belkin support page...
you can download the driver from the link provided here...
before downloading select the appropriate version fo the adapter...
you can find it in the adapter or adapter statrs with letter v....
once you downloaded tranfer it to your laptop using a pendrive/cd and start executing it and follow the onscreen instructions....
Feb 25, 2010 | Belkin 802.11g Wireless Notebook Network...
I have a Belkin Wireless Notebook Network Card (F5D7010). The problem is that I only have USB Ports on my computer. Is there an adapter of any sort that will work with this card??? Thanks in advance.
YES. There are some PCMCIA readers that connect to your PC/Laptop USB. Here is one on eBay:
Apr 25, 2009 | Belkin 802.11g Wireless Notebook Network...
Reply to advice
wts the light status of the router and are able to open the router page and wts the Adsl connection status is it connected.
Nov 03, 2008 | Belkin 802.11g Wireless Desktop Network...
Belkin Notebook card and its wireless access point
In Ideal scenarios, you should just plug in the card in the notebook and it should get installed automatically.
Thanyou may scan for the available networks and you should be able to seethe network of your Netgear router(Assuming that the Netgear you havementioned is wireless capable and configured).
You can connect to the network and it should work fine.
Check this link
Let me know what happens.
Jul 10, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin (F5D7010) 802.11a, 802.11g/b Wireless Adapter Logo
569 people viewed this question
Top Belkin Network & Wireless Adapters Experts
Martin Murray
 C. Dante
C. Dante
Are you a Belkin Network and Wireless Adapter Expert? Answer questions, earn points and help others
