Question about Fellowes DM15C Shredder
How do you open the shredder - Fellowes DM15C Shredder
Source for gear for fellowes 301101 DS-1 paper shredder
Replacement Parts - Paper Shredders Can I get my Fellowes paper shredder repaired or purchase parts for it?
The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
*** Please note: If your shredder is still within the warranty period, we ask that you do not open your shredder until speaking with a Fellowes Representative, as opening the unit may void your warranty.***
Fellowes office/commercial shredders (large shredders that cannot fit under a desk) are repairable and parts will most likely be available. Please do not try to repair the shredder yourself or you will void your warranty. Models included in the office shredder line are 125i Series, 225i series, 325i series, 380 series, 420 Series, and 480 series.
If you would prefer to have a local servicing dealer provide repair service to your office shredder, and would like to find a dealer in your area, please see the below link to search for a dealer by zip code.
http://www.fellowes.com/Fellowes/site/support/support_authorizeddealers.aspx
To order replacement parts, or if your model shredder is not listed, please click the "Ask a Question" tab above to ask us about your shredder. *** Please be sure to include your serial number from your shredder for the fastest service ***
Our office hours are 7:00 AM to 7:00 PM, Monday through Friday Central Standard time.
Jan 22, 2015 | Fellowes Office Equipment & Supplies
How to open fellows s701 cm shredder?
There are six Phillips head screws around the perimeter of the underside, plus one more hidden screw in the center under a label. Then the cover just lifts off ...
May 18, 2014 | Fellowes S701CM Shredder
Small strip of sticky paper stuck in shredder opening so the shredder runs continuously. How can I correct this?
Plain and simple you will have to get that paper out by any means necessary. Long tweezers, needle nose, knitting needle, vacuum....etc. Unplug while you are doing that.
Jan 05, 2013 | Black & Decker CC1000 Shredder
Hi I have a Aurora AS1512X it was working fine until I emptied the basket. It only goes in reverse now. Nothing lights up when I press auto for forward.
I was having the same problem with my shredder. Always make sure your shreder is not under warranty before you open it because once you open the shredder it voids the warranty with Aurora! I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Mar 28, 2011 | Cross AS1512X Shredder
THe shredder goes in reverse, but not forward. I can see some paper in the opening, but none in the teeth. Is there anyway to take apart the top?
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. Don't open your shredder to repair it yourself because it will void your warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Feb 21, 2011 | Aurora Electronics AS1015CD Cross-Cut...
The shredder developed a jam. I removed the bin and the top of the shredder. I removed the shredding mech. and removed the paper material. Reassembled the shredder. Shredder starts up when paper is...
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Oct 27, 2010 | Royal VF880 Shredder
Shredder will shred about 3/4 of a sheet of paper then shuts off. If you open the shredder door it resets the power switch and you can finnish shredding the remaining paper. is there easy access to the...
If your shredder has a feature where it won't run with the door open/shredder off the bin, you probably need to make sure that the safety is engaging properly. If the motor seems to sound very labored when it runs, unplug it, and check the blades to make sure there's not a lot of extra stuck in them. You may need to clean them and lubricate it with special shredder oil ONLY.
Nov 24, 2009 | Fellowes Office Equipment & Supplies
Shredder won't run unless Istrike it on the side.
go buy another one , stick this lemon in the box and return it ! lol
sounds like you got a bad solder joint thats causing an intermitant problem until you bang it and complete the connection,, or a switch inside is bad or dirty , open it up check it out .
Mar 10, 2009 | Techko SH1524CP Shredder
How to empty a Tech Solutions TS8000 shredder
Pull the top of the basket toward you and the top of it should swing out. Then you can lift the basket up and out once the top of the basket is partly open. Hope this helps. Have a good day. Mac =)
Mar 09, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Fellowes DM15C Shredder Logo
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
