Question about Samsung Dryers
Samsung DV405 Electric Dryer stops after a few seconds
Samsung DV405 Electric dryer runs a few seconds and stops
SOURCE: Samsung Electric Dryer
I have had the same problem with mine, they (being the repairman) came out and have replaced the sensor and the board and it still does this, they said that there is nothing else that they can do. Don't know what I am going to do from here
Posted on Sep 26, 2008
  • 95 Answers
SOURCE: must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Posted on Dec 30, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 686 Answers
SOURCE: Can I run the dryer vent vertical and how high?
yes
Posted on Apr 08, 2009
SOURCE: maytag mdet446ayw runs a few seconds and shuts off
maytag dryer mdet446ayw runs for around 30 seconds then shuts off
Posted on Jan 17, 2010
Samsung dryer. It starts, but it doesn't get hot?
Samsung Dryer Diagnostic Repair & Diagnostic - Not ...
? 19:33
https://www.youtube.com/watch?v=a-8UFyRXBDg
Feb 7, 2014 - Uploaded by ApplianceVideo.com
Troubleshoot your own Samsung Electric Dryer that has some of the ... It powers on but when I get start nothing happens... drum spins but not ...
How To Fix A Clothes Dryer That Is Not Heating Or Drying ...
removeandreplace.com/2013/.../fix-clothes-dryer-heating-drying-clothin...
Sep 21, 2013 - At times your dryer can overheat and this can cause the motor that turns the ... Clothes Dryer Will Not Stay On After Pushing Start Button My dryer will run if I ... I have tried the trouble shooting tips for a dryer that doesn't dry but to no avail. ..... I have a 3 year old electric Samsung dryer and it stopped heating.
[FIXED] Samsung dryer runs, no lint clogs, good airflow, but no ...
forum.partsdr.com > Forum > Appliance Repair Help > Dryer Repair
Mar 12, 2013 - 16 posts - ‎4 authors
I want to check the third harness it but it doesn't look to slide out too easy once I remove the one phillips screw. ... Dryer gets nice and hot now!
Jan 19, 2016 | Samsung Dryers
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
Dv218aew Samsung dryer shuts off itselft after 30 seconds
Bad venting causing overheat? bad thermostats hi limit and cycling? thermal cutt off. bad moister sensor in the drum? giving wrong reading and cuting it off?
Sep 04, 2014 | Samsung DV218AEW Electric Dryer
I have a maytag Neptune NDE3000AYW and the dryer turns on, runs for a few seconds and stops. took it apart and cleaned all the lint and dust. after a while it will run again for a few seconds and stop. ...
Check the door switch. It may be at fault here. Open the door and hold the switch by hand and start the dryer. The switch should have a firm resistance to it when you push it. If you should find this bad, here is the replacement switch. If the switch is ok, then the motor is bad. Here is the motor to order.
Keep me posted!
Nov 05, 2012 | Maytag MDE2600 Electric Dryer
Samsung Dryer starts for 5 seconds then stops, but drying time still counts down.
I got the same problem and I tried to take off the belt let see the motor still running by itself but it still run for couple second then stop.
Jun 12, 2012 | Dryers
My Frigidaire Affinity dryer (mod# AEQ6000ES2) turns on but drum will only turn for a few seconds then stop. What could be the problem and can I fix this myself?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 24, 2011 | Frigidaire AEQ6000ES Electric Dryer
Samsung dryer DV328AER doesn't turn off
My Samsung dryer 8KG (SDC3K801) is not turning off after completed the cycle time. The panel showing end but the drum still running. If I choose Synthetics extra dry with auto cycle time 49, when the timer at 6, the display increased again to 25. It's seem the dryer is not stopping forever. Any suggestion please!. Thanks
Jul 20, 2009 | Samsung DV328AE Electric Dryer
Electric Kenmore Dryer runs short time (seconds) and then stops.
your thermostat/s are not doing their jobs. They are allowing your dryer to overheat and also if your dryer has not been cleaned out on the interior you might want to do that. I've taken out globbs of lint build-up in them.
Mar 25, 2009 | Dryers
Kitchenaid prestige dryer model keys677EQ1
I have a KItchenAid Presitge Electric Dryer; Model #YKEYS677EQO. It just shut off. I tried resarting it but all I get is a humming noise. This humming noise only lasts for about a couple of seconds then I get nothing. The barrel can be turned manually.
Dec 15, 2007 | Dryers
Dryers Logo
74 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
