Question about Emerson Televison & Video
Radio shack replacement parts
Does radio shack have 1zb220-y diode
Can I get a diagram for the circuit board for my te 604, I need to replace three of what look to be three leg diodes
good luck on radio shack Ours closed 3 weeks ago and heard many were gone now .those would most likely be diodes not resistors tho
May 15, 2015 | MTX Thunder Elite 604 TE604
Meter doesnt move when i key up on my radio shack cb why
give it a flick with your finger to see what happens.It may work or it may not but whatever it is a diode that controls the meter and that diode needs to be changed.there are 4 diodes in the front of the radio,change all 4.
Aug 21, 2014 | Radio Communications
447 will not take power from power suply
  • If you have an inline fuse make sure to check and replace it if needed. If the radio was hooked up backwards then you need to go to radio shack and pick up a replacement diode. 1N4001 will be the diode you need. It allows current to travel one way but not the other. When you hooked the radio up backward it blew, like a fuse. Here is the diode at Radio Shack. http://www.radioshack.com/product/index.jsp?productId=2036268
  • When you pull the bottom cover off you will see this diode in the board right by the power cord connector for the radio. Most of the time they will be chipped or even split after blowing from reverse polarity. Pay attention to the little "arrow" on the diode because there is a negative and a passive to diode. Anode and Cathode as it were. The Anode flows to the Cathode. The "tip" of the arrow is the negative side.
  • Look with a flashlight to insure you did not blow a tracer too.
  • Hope this helps.
Oct 31, 2011 | Radio Shack TRC-447 CB Radio
Do you sell protection diodes for a superstar 3900 the code on the diode i need reads SR1K4 or do you know where i could get one thanks
  • Hi, I can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 01, 2011 | Galaxy Radios DX- 88HL Base CB Radio
Im a trucker so when i plug my power wire the fuse blow why
You probably plug it in backwards at some point. When you do that you blow the polarity protection diodes. They are so you do not blow the radio.
Get a N14003 diode from radio shack.
Open the radio's bottom cover where the speaker is. Watch the speaker wires.
Near the back right of the board where the power cord plugs in left of the transformer, look for D23. Its the same diode as the one you bought from radio shack. It is most likely burnt.
Remove that one and replace with a new one.
The radio should work fine now. Be careful when plugging that thing in.
Oct 11, 2009 | Cobra 29 LTD CB Radio
Need to find a diode for samsung42" lcd # on peart is 800 416 o epcos can anyone help me find this or a replacment?????
Ok, i have located the part you need and, i will post a link to a parts store below. this is a direct link and you can order it from this page as well.
CLICK HERE FOR YOUR DIODE
Please rate and god bless:)
Apr 28, 2009 | Samsung HCM4215W 42" Rear Projection...
Radio shack cb radio 21-1703
OK. I do not know the exact number for the diode off hand, because I don't have the same radio in front of me. On most cb radios, this diode is usually located on the component side of the pc board, close to where the positive lead solders to the board. Most of the time when it burns, it just becomes brittle.
If you do replace it on your own. The diode is called a rectifier diode, which you can pick up at radio shack or at partsexpress.com. The part number is between 1N4001 to 1N4008. When installing be sure to observe polarity, making sure that the side with the silver band is facing the direction of the arrow.
If I can help anymore, please don't hesitate to ask.
Dean Pitts
Rollin CBs
rollincbmods@yahoo.com
Jul 17, 2008 | Radio Shack TRC-503 CB Radio
RCA R52WH74
i am unfamilar with your original post... can you please tell me the orginal problem... i will gladley help you out.
Jun 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony rear projection tv How to de-solder
I would suggest not to desolder that transformer until you are certain that is defective.
Try to change D6116 and D6301 first.
You can try Radio Shack or check this site.
Good Luck.
Apr 10, 2008 | Sony KP-57WS520 57" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
