Pilot light blinking - Heating & Cooling
Electrical ignitor on Kenmore Hot Water Heater Not Working
The water heater uses a thermocouple to generate a small voltage from the pilot light. This voltage is used to blink the led and allow the main gas jet to turn on. Either your thermocouple or the wiring from it has failed and needs to be replaced, or realigned if perhaps it moved out of position above the pilot light.
Mar 26, 2017 | Rheem 40 Gallon FVR NATGAS Low WATER...
Lowe's hot water heater pilot light will not stay
If it is one of the new ones with the fancy gas control and the blinking light... does the light blink?? or not??
If it is blinking then the pilot should stay lit...
If it will not blink then the sensor is bad or not in the right place...
Or... the gas control is bad... this is happening alot...
If it is brand new... take it back...
heatman101
Sep 05, 2011 | Whirlpool Water Heaters
Heater # GMF8GHS8GDS8 where is the pilot light and how do you light it?
This unit uses an electronic ignition and not a pilot. Look for a small viewing port in the lower section of the furnace. There should be a LED light if you look in the port. If it is blinking, count the number of blinks and look on the reverse side of the front panel for a diagnostic chart. It will give you a starting point where to look for the problem.
Jan 10, 2011 | Goodman GMS90703BXA Heater
What does it mean when your 2005 honda pilot maintenace light blinks 10 times
nothing it could blink a 100 times it just means you need to have it serviced.
Oct 07, 2010 | 2005 Honda Pilot
Blinking green drive light
There is some problem with your transmission, get an engine analyser then you can see the error code i.e. telling the problem faced.
Apr 06, 2010 | 2005 Honda Pilot
2003 honda pilot, remote control doesn't work even with new battery , light on remote control doesn't blink
did the light blink when it worked? It may need to b reprogrammed. check the owners manual, it should tell you how to program. If the fob is dead, check ebay for a new one, usually 50 bucks and the reprogram
Dec 06, 2009 | 2003 Honda Pilot
Canon pixma ip1300
cannot print on blinking pilot light green and yellow
Jun 19, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
SAMSUNG HLS4676SX UNEXPECTEDLY SHUTS DOWN DURING USE. PILOT LIGHT (GREEN/LOWER RIGHT CORNER) BLINKS FOLLOWING SHUTDOWN. PROBLEM CAUSE? SERVICE MANUAL COVER THIS PROBLEM?
Mar 10, 2008 | Televison & Video
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
