Question about Canon CLC 1140 Copier
Error 000400-0100 canon ir 5055 - Canon CLC 1140 Copier
  • 523 Answers
SOURCE: installing staples in a Canon imagerunner 5055
Open the finisher door and you will find the place, it is in the front side. Regards
Posted on Mar 02, 2009
  • 199 Answers
SOURCE: which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Posted on Jun 15, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
  • 3 Answers
SOURCE: error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
Posted on Jun 04, 2010
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
IR 5065. Where is waste toner receptacle located?
You must empty the toner box and with soft clothes try to clean all the sensor window on used toner box and put it again.
Mar 03, 2016 | Canon Image Runner Toner Black...
I have error sc 00001-01 in my copier canon ir-5055
Check the connector of each thermistor,replace if neccesary.After fixing the problem reset the error in service mode:COPIER<FUNCTION<CLEAR <ERR,and turn machine OFF
Jan 14, 2015 | Canon Office Equipment & Supplies
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
Canon ir 5055 has an error e000004-0010. how di I fix this?
This is a fixing error code - there is too much temperature difference detected by the thermistors. Mostly a error reset will take care of the problem. You have to get into service mode first. Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. DO NOT keep resetting the code. There is something wrong with the copier that needs to be taken care before major damage is done to the copier. Good Luck
Dec 08, 2010 | Canon imageRUNNER 5570 Copier
Jam code 0211 in ir 5055
try to clean all rollers and look for any sensor damadges.
... or call service!
Aug 18, 2010 | Canon imageRUNNER 5000 Copier
Jam code 0211 in canon ir 5055
Clean or replace roller after fusing unit.(heater) Slide out middle section>Lift green handle on left to expose rollers.
Aug 18, 2010 | Canon ImageRUNNER 1670F Copier
Which one is better to buy IR 5075 or IR 5065
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
Waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
May 26, 2009 | Canon imageRUNNER C3170U Color Copier
Installing staples in a Canon imagerunner 5055
Feb 20, 2009 | Canon imageRUNNER 5000 Copier
Canon CLC 1140 Copier Logo
100 people viewed this question
old marine
old marine
