Question about Cobra 148 GTL 120-Channels Base CB Radio
Zachery t wont transmit or put out wattage - Cobra 148 GTL 120-Channels Base CB Radio
    Genius:
  • Cobra Master
  • 1,795 Answers
Main IC or final with driver
Posted on Sep 01, 2014
Galaxy DX 55HP stopped transmitting, but will receive. When the mic is keyed the power meter goes past max and wont transmit. Tried different mics and no difference
connect to a meter. if there is rf power on a watt meter at full wattage. then the am regulator transistor is bad. less than $5 part.
Mar 29, 2014 | Galaxy Radios DX55HP 10 Meter Radio
Uniden tech help
I have a a uniden teddy r that won't recieve.
Jan 01, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
I have a galaxy 55 v that will transmit and receive but has no swing
I would turn do the watts to about 3.5 and that radio should swing.Sounds to me like its trying to but the wattage is stopping it.Experiment with it and find where you want to set it.
Jan 26, 2013 | Radio Communications
How many watts do midland walkie talkie xt20 have?
These are FRS/GMRS (Family Radio Service/ General Mobile Radio Service) radios. The legal power limit for FRS is 500 milliwatts - or 1/2 watt. GMRS on the other hand is limited to a much higher 50 watt level. The wattage you transmit determines if you need to have a GMRS license. Most GMRS radios are in the .5- 5 watt range however.
The likelihood of your XT20 being a 1/2 watt out on both FRS & GMRS is very good. For Midland (or anyone else for that matter) to produce a radio with a 1 watt output that can run on just 3 "AAA" batteries would be quite the feat! If Midland did do this, the radio's battery life would extremely short. To balance the needs of light weight and battery life, output power needs to be reduced.
Claims of 20 miles is crazy. If you had these radios on mountain tops 20 miles apart - with a clear line of sight between them - MAYBE - you could hear one on the other. This would need to be done under only the most ideal conditions. The actual distance you can expect to get out of a pair of any brand FRS radios in "real world" conditions (line of sight blocked by trees and buildings) is about a mile.
An FRS/GMRS radio limited to 1/2 watt output when used on a GMRS frequency that is close enough to access a GMRS repeater system could easily cover 20+ miles. The key here is having a license and access to the repeater. Repeater owners take a dim view of unlicensed users access their repeater.
Channels 1 thru 7 are FRS and GMRS. That is, if transmitting .5 watts, you can use it as FRS. If transmitting more than .5 watts, you will need a valid GMRS license.
Channels 8 - 14 are expressly for FRS. Only .5 watts transmit power is permitted.
Channels 15 - 22 are expressly for GMRS at any transmit power up to 50 watts. Even if transmitting .5 watts, you MUST have a valid GMRS license on these frequencies.
I know - more infor than you wanted and no vclear cut number for wattage - but there's no info on these radios on Midland's site or anywhere else that I could find. Good luck!
Jun 16, 2012 | Midland XT20 Two Way Radio
I press in the clutch but i cant put it in gear wont even move a hair
Well it could be that the Master Sullinoid Cyllinder is not engaging the clutch. More than likely in my experience its not a good sign. if you know a good mechanic, I would suggest having them look at it and see what they recommend.
You dont want to have to get a new transmition and if the fluids in the transmition are low and this pressure plate wont engage, dont chance it.
A new transmition is upwards of $1700.00 just for the transmition.
May 28, 2012 | Garden
Radio get hot when modulation bought fan seems to be staying cool
Radio most likely needs an Transmit Section alignment or has a modification in it that is causing this overheating condition. Just a guess i would say that final bias or carrier wattage/deadkey is set to high.
Sep 02, 2011 | Connex 3300 240-Channels Base CB Radio
My customer has 6 motorola max trac vhf radios. all have same problem, they transmit just fine & then they just quit transmitting, they still receive but wont transmit until they turn unit off &...
If this is a new install, it is likely noise from the vehicles electrical system scrambling the processor of the radio. Put a filter on the power leads and check your install.
Aug 26, 2009 | Motorola T9580RS Two Way Radio
Transmition problem
No forward or reverse? After you installed it how much fluid were you able to get in it before it read full?
May 27, 2009 | 1997 Dodge Dakota
My pc wont reconize any memory card Bigger than 2 GB
Hi, you need to check your power supply to see how many watts it is. If you have a low wattage PSU then your 8GB card may need more watts to run. If you have a ow wattage PSU get a new one with more watts. Hope that helps.
Mar 12, 2009 | Computers & Internet
Cobra 148 GTL 120-Channels Base CB Radio Logo
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
