Question about Sanyo Televison & Video
My tv is coming up with a split screen when connecting DVD player
    Genius:
  • Sanyo Master
  • 1,552 Answers
If it is a "3-D" DVD player, and your TV cannot handle "3-D" output, you get a "split-screen" (whole picture on left 50% of the screen, whole picture on right 50% of the screen).
Posted on Feb 15, 2015
Wizard_Yo
  • 3 Answers
SOURCE: memorex dvd player pscan split screen
Memorex MVD2042 - The only switch on the back of the unit had gotten bumped when something fell behind the unit, thus causing the same issue mentioned here. Looking at the front of the unit, the switch is straight back from the disc tray on the left. (of course, if you're looking at the back, it's on the right side) This switch is for "Progressive Scan" either "on" or "off" Thanks, Wizard_Yo
Posted on Jul 31, 2006
  • 3 Answers
SOURCE: JVC DVD player stuck in Split screen
the player is set to progressive scan mode.use relevant button on remote to reset to interlace mode. Duane,S/Africa
Posted on Sep 01, 2007
thank you!!! it worked!!!
Posted on Oct 02, 2008
SOURCE: can't get pscan split screen off dvd player, DSAY
I had the same problem... there is a switch in the back that got touched
Posted on Jan 30, 2009
I had the same problem with mine. I flipped the switch on the back and it worked instantly, hope yours does too.
Posted on Mar 18, 2009
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
Feb 26, 2015 | Samsung DVD-V3500 DVD Player/VCR
We have xbox360 it's hooked up to sansui sledvd244 how do i get split screen so there can 2 players please help
Minecraft Xbox 360 is a multiplayer game by default. Players can join online or locally via connected controllers. Split screen is a way to play multiplayer on the same console. To play split screen, the Xbox must be outputting a resolution of 720p or higher.
you must have an HD TV for split screen. Connect Xbox to tv with an HDMI cable. Start mine craft when you've logged on with your first controller enter your desired world then pause the game. Turn on and sync your other controllers if they haven't been connected before.Log in those controllers and press Resume Game.
  • Your television screen should be split into two or four parts depending on how many controllers are connected.
Dec 06, 2014 | Sansui Televison & Video
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Dvd player is playing a vertical split screen
If the TV does the same with two different DVD players, it must be a menu setting on the TV. Look through the TV menu options.
Jul 24, 2013 | Panasonic DVD-RP56 DVD Player
I have a mvd 4544 dvd combo hooked it up to my new vizio tv and now i get a split screen with a yellow pscan box in the middle.
Do you have the dvd player set up as progressive scan? Most likely this is a settings issue. How are you connecting the dvd player to the tv as in what type of connection? Once I have more information I can assist you further.
Thank you,
Lee
Dec 11, 2009 | Memorex MVD2022 DVD Player
Memorex dvd player pscan split screen
Feb 26, 2009 | Memorex MVD2042 DVD Player
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Split screen picture
Your DVD player is set to the 480p (progressive) scan mode. Place it back to the 480i (interlaced) mode and it should work normal.
May 14, 2008 | Disney D7500PDD Portable DVD Player
Televison & Video Logo
73 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
