Question about Panasonic KX-FPG376 Plain Paper Thermal transfer Fax
Number of rings
How do I increase the number of rings before machine answers?
  • 1,959 Answers
Press MENU, then enter #06, then press the number of rings before the fax picks up by pressing 1,2,3, or 4 (4 being the maximum number of rings)
Press SET, then press MENU again to exit. Best of luck!
Greg
Posted on May 21, 2009
  • Greg Margossian
    Greg Margossian May 22, 2009
    Haven't heard back from you. Hope the solution supplied answered your question. If not, pls post back.
    Greg
KX-TG5621C changing number of rings
The KX-TG5621 isn't an answering machine. It will ring until you answer, some answering machine picks up, or the caller hangs up.
To change the ring count on your answering machine, refer to the documentation for that answering machine. If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
Oct 17, 2014 | Lands Phones
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jan 28, 2014 | Vtech DECT 6.0 Digital Cordless Phone
On the uniden TRU9466 is there any way to increase the number of rings before it goes into voicemail?
The TRU9466 isn't an answering machine. The number of rings is controlled by whatever answering machine or voicemail system you have on your phone line. Please refer to the documentation for the answering machine or voicemail system to change the ring count.
If you need further assistance, please reply to this post and specify the answering machine or voicemail system.
Jan 22, 2014 | UNIDEN AMERICA CORP Uniden TRU 9466 -...
Increase number of rings from 14
The number of rings is controlled by the answering machine, not the phone. What make and model answering machine do you have on your phone line?
Oct 30, 2013 | Uniden Cordless Phone
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
Answer phone responds too soon
The usual numbers of rings before the machine answers is 2 or 4. If that is not enough, you are out of luck. If it's 2 now and you want 4, there should be a menu button you can press, and when you hear "number of rings" use the up/down arrows to increase the number. Then press the "set" button. Hope that helps.
Mar 05, 2010 | Uniden Cordless Phone
Increase the number of rings
Press
function
64
set
look at the printout
look for number of rings
to set the parameter
press
function 74
set
Feb 07, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I have a discontinued phone and have lost the instruction book and need to figure out why the fax machine is not letting the answering machine pick up.
you have both the fax machine and the answering machine on the same phone line.
The fax machine and the answering machine are set to answer in a certain number of rings.
In your case the fax machine is set to answer the line in less rings than the answering machine. You have to increase the number of rings of your fax so that the answering machine will work.
Aug 06, 2008 | Lands Phones
Panasonic KX-FPG376 Plain Paper Thermal transfer Fax Logo
173 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
