Lg lcd tv blurry picture
DISH network, HD channels, 47 inch TV picture not picking up HD
3 Suggested Answers
  • 3 Answers
SOURCE: Magnavox 52 inch HD Tv connected to a Dish Network
have you tryed to go to setting and letting it yout tv know that you want sound onto the hd channels.? if you have any more problems joust contact you coustmer service for dish network. problalby your tv is not compatible and you need an hd receiver. i have dish network myself and just upgraded my receive to hd.
best of luck- JD
Posted on Nov 18, 2009
  • 9 Answers
SOURCE: 3D tv issues with HD channels on Dish Network
check screen resolution of your lcd tv & receiver too
Posted on Aug 24, 2012
Aug 24, 2012 | Dynex DX-L42-10A 42 in. LCD TV
I have the same issue with my new LG 47lv5500. I too have time warner settings of 1080i but the sound on hd channels comes and goes. Picture is fine. When I switch back to non hd channels the sound is also...
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Aug 25, 2011 | LG 47 47LV5500 47 LCD TV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
I have a Vizio 47 inch LCD HDTV hooked to a Dish system. The volume fluctuates from very loud to very soft between ads and programs. It also goes from moderate volume to very soft within a program. Help!
Either unplug dish from tv or use the antenna side which is HD and program channels and see if volume the same, if not and is OK then it's your Dish bring your sound down or audio cables bad.
Feb 18, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
I have a 20 inch sanyo hd digital hooked up as a second tv on dish network receiver. I had to unhook it temp and when I hooked it back up, no picture. I tried channel scan and nothing. How can I get the tv...
bring the tv out to the main tv and hook it up to that connection to determine if it's the TV or the connection. Or try hooking up a VCR to the tv while the TV is set to CH 3. Do you get a blank picture or a snowy Picture?
Sep 20, 2009 | Sanyo Televison & Video
My 47" LG has an internal HD reciever but it isn't picking up any HD channels.
Is it connected to an antenna? Did you do a channel scan for digital channels? See www.dtvanswers.com or http://dtv.gov/iguide.htm for more information.
Sep 03, 2009 | LG 47LC7DF 47 in. LCD HDTV
Blurry picture when hooked up to direct tv.Why?
try lowering the sharpness on your tv, because if the sharpness is to high it will make NonHD objects look blurry, also try changing the input cable or type of input.
May 20, 2009 | Element Electronics FLX-2610 26 in. LCD...
Blurry picture
In the store they use an HD source and connection. Is your cable box HD? It will have component or hdmi connections if it is.You have use either one to get HD everything else will be SD(standard def).And you have to be on an HD channel.Digital cable refers to how the signal is delivered doesn't mean its HD. SD channels on digital still look bad..
Rustym62
http://www.the-tv-dude.typepad.com
Apr 28, 2009 | Televison & Video
PICTIRE SETTINGS
1. you should have a HD source, such as direct tv with HD channels
2. You need to connect this source with a HDMI cable
3. Make sure all the setting match from the source to the tv
May 11, 2008 | LG 47LC7DF 47 in. LCD HDTV
Samsung HC-P4752W Blurry ONLY on HD Channels
Similar problem, then about 2 weeks later the SD convergence went out. Changes convergence Amps,,, Now I'm trying to learn what 2 red flashes mean now when I try to power it up,,, it flashes twice then shut down into standby mode,,, I got no picture after installing STK392-040 chips, thinking about trying another set as atleast I had blury picture before. No solder shorts of opens that I can find. TV has always been a pain,,, locking up once in a while such that you can't change modes,,,
Jul 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
