Question about Moen Plumbing
How to remove a moen 1224 cartridge - Moen Plumbing
5 Suggested Answers
  • 127 Answers
SOURCE: how do i replace a moen faucet cartridge
if it is a 2 handle faucet, (thinking that because of the cartridge number) then you take the handle off. There will either be a nut that you can use a crescent wrench on or it could be the type that has a recessed nut....if that is the case there is an inexpensive tool you will need to reach down inside to undo the nut that is holding the cartridge in. Once the nut is off...you grab the top of the cartridge with a pair of channel locks and pull it out....reverse the steps for install.
Posted on Oct 25, 2009
  • 244 Answers
SOURCE: how do i remove the cartridge from a moen pull out spayer
call moen. get free new cartridge. with white plastic tool and vce-grip, you'll get it out.
Posted on Dec 18, 2009
  • 102 Answers
SOURCE: cannot remove moen sink cartridge
MOEN cartridges can be EXTREMELY difficult to remove sometimes. Be sure the horse shoe clip is out. Then you can use a crescent wrench and carefully turn the cartridge, once you get the cartridge to turn a little you can try to pull it again. They actualy make a tool to pull these. They run around $10 at your local home improvement store. The tool takes the place of the crescent and puting the handle back on to pull it. Hope this helps.
Posted on May 05, 2010
  • 7 Answers
SOURCE: replaced moen teo handle cartridge 1224 now faucet
the lines the cartage attaches to will have seals or teflon tap. if the seal has a small nick, it will leak. Or if the tape was applied in the incorrect dircection or was cut it could also creat a leak
Posted on Jul 21, 2010
How do i fix my leaky moen bathroom faucet?
Moen faucets are easy to repair. The cartridge you're looking for is most likely the #1224 cartridge, sold in pairs, and available at almost any home improvement store.
Shut the water off, unscrew the handle, remove the nut that holds the old, cartridge in, swap it out, and put the handle back. The whole job should take you about ten minutes.
Good Luck!
May 21, 2014 | Plumbing
Do any plumbing stores carry moen 12801 replacement cartridges
I am not familiar with that cartridge, but most hardware stores and plumbing supply houses should have Moen parts. #'s 1224, 1225, 1200 and 1222 are the cartridges I'm familiar with.Bring the part with you.
May 19, 2014 | Moen & Replacement Cartridge
I need replacement part for bath sink cartridge 4570
The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
Replaced moen teo handle cartridge 1224 now faucet
Jul 19, 2010 | Moen & Replacement Cartridge
Faucet is leaking. Can you tell me if this is a
yes it is a cartridge replacement,the cartridge is,should be all that you need to replace.you did not list what kind of faucet. so here is a few number's. some bath/shower valves' take#1225-(plastic) this is also use'd in some kitchen,lav, model's.two handle faucet's#1224,the "posi-temp"#1222 is a tub shower only,there are cartridge puller's available,and recomened them,one is made by moen,another by brass craft,i have pulled cartridge's with out,so it is up to you.hope this help's.
Nov 03, 2009 | Moen & Replacement Cartridge
Replacing Moen O kitchen faucet O ring
if it is dripping from the spout then there is a cartridge that needs replaced...1225 for the single handle type and 1224 for the 2 handle type. Moen does not use O-rings in their valves. If it leaking around the base of the spout there is an oring kit that you will need and you will have to pull the spout off to access them. Most Moen faucets use a 117 kit for the spout but there are some different ones.
Oct 19, 2009 | Moen & Replacement Cartridge
0n a Moen TL2383--what do i do to get hot water thru only cold comes out
The tl2383 is just a trim kit...if you have a 2 handle shower valve and it is moen then the number is 2919....you just need a new cartridge if you are not getting any hot water....it is a 1224 cartridge.
Oct 09, 2009 | Moen 2919 Chateau Two Handle Tub and...
How do i replace a moen faucet cartridge I have model # 87480 & need to replace the cartridge part # 1224
Oct 07, 2009 | Moen & Replacement Cartridge
Plumbing Logo
102 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
