Question about Cell Phones
Connecting to ipad - Cell Phones
Can't get sound from my IPad when plugging into headphones or competer what could
Posted on Oct 11, 2014
How do you connect ipad to computer
To help you connect your ipad to the computer, please follow the step-by-step instructions given below:
- Turn both the computer and iPad ON before connecting.
- Plug the iPad's docking port into the appropriate end of the dock connector-to-USB cable.
- Plug the USB end of the iPad's dock connector-to-USB cable into an open USB port on your desktop. If iTunes doesn't open automatically, open the program to sync files and apps between the devices.
- Do not disconnect while the iPad is syncing or the sync won't complete.
- Remove either end of the cable to disconnect your iPad from the PC.
- After the first connection, you may choose to connect the two via Wi-Fi so you don't need to use the cable.
- Using iTunes, you can sync your audio, video, photos, apps and documents. This lets you transfer important files and apps you use for your business between your iPad and computer.
GuruAid.com
May 15, 2016 | Tablets & eReaders
I can't connect to ITunes
connect the pad to your computer and open iTunes, turn off the ipad, then hold both the lock and the home button for 10 seconds, then release the lock button while continuing to hold the home button until iTunes recognizes the iPad.
iOS Device not recognized in iTunes for OS
Jun 18, 2014 | Apple iPad Tablets & eReaders
How do I connect my Ipad to my windows laptop?
Install a copy of ITunes from Apples store on the PC.
This will interface between the pc and the Ipad.
Apple iTunes Download iTunes Now
Jun 16, 2014 | Acer Computers & Internet
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
How do I connect to Internet on my Ipad?
Two possible options:
Use Wifi to connect the iPad to your home wifi. Read this: iOS Connecting to Wi Fi
IF your iPad it equipped with cellular option (3G ,4G depending on iPad generation) you can insert a sim card with a mobile data plan to connect to the internet. Here are several reads for several providers:
Verizon How to set up new Cellular Data account on iPad
Sprint How to set up new cellular data account on iPad
AT&T How to set up and manage cellular data account on your iPad
Learn about cellular data settings and usage on your iPhone and iPad...
Apr 26, 2014 | Apple Ipad I-pad
Bluetooth video feed to iPad
Normally you can't connect a camera to an iPad. If you want to put pictures from your own camera on the iPad, you can use a Camera Connection Kit. for the iPad 1 to 3 (30 pol connector) there are two items. One you can put in a SD (SCHC) card and import jpg pictures to the iPad. If your camera has no SD cards, you can use the USB connector. With a USB cable you then can connect the camera and you can retrieve the jpg pictures from the camera to the iPad. for the iPad 4 gen and 5 gen you have to buy the lightning connector with SD card reader. The camera connection kits only work on iPad not on iPhone. The card I now will mention, also work with iPhone.
Last option is to buy a Eye Fi card or a Trancend WiFi card, as long as your camera is compatible with such a card. (read the manual) and get a free app from the app store for the card you bought. Theen you can view or download the pictures while you are shooting. Last option is slow and while connected to the WiFi card you can't access the internet is you have a wifi only iPad.
Nov 28, 2013 | GE Add-On Wireless Digital Color Camera...
IPhone deletes my contact names when I sync it to computer! Leaves the numbers, delete only names.
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
To prevent unprompted syncing for a specific iPod, iPhone, or iPad:
  1. Connect your iPod, iPhone, or iPad to your computer.
  2. In iTunes, select your device (below Devices).
  3. Click Summary, and then deselect "Open iTunes when this Device is connected."
To prevent unprompted syncing for all iPod, iPhone, and iPad devices:
  1. In iTunes, choose Edit > Preferences.
  2. Click Devices.
  3. Select "Prevent iPods, iPhones, and iPads from syncing automatically."
    If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
Dec 18, 2012 | Cell Phones
Comcast ipad wifi problem
I'm sure you've done this but try turning off wifi on iPad and then turning back on. Does your wifi name show?
Jun 17, 2017 | Apple iPad 32 GB 3G Tablet PC
Cell Phones Logo
430 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
