Question about Bosch Dle 70 Laser Distance Measure 70m Range Metric Measuring
Metric/imperial - Bosch Dle 70 Laser Distance Measure 70m Range Metric Measuring
Router bits continue to slip out of the Skil Router. I have it as tight as possible...what is the problem?
router bits shaft come in 2 sizes
metric and imperial
using imperial shaft in metric collets may be the problem
Feb 21, 2018 | Skil Tools & Hardware - Others
My dodge journey 2015 change to miles from km I would like to change it back
Hey, all you need to do is change your settings from imperial to metric or metric to imperial.
Your owners manual will have the exact steps on how to perform that, be sure to give that a good read if you haven't yet about 15 minutes and you'll learn a whole lot of cool features you might not have known about your car yet.
Nov 07, 2017 | Dodge Cars & Trucks
How to find diffrent unit standerds relating to boilermaking
The basic principle is that it would use the customary or legal standard units for the particular country.
For instance in the US, although the metric system is legal, the American imperial (modified British) system is still used. Hence boilermaking specs and drawings would usually be in inches, feet, US ounces and pounds etc.
In Australia it has all gone metric long since, and units are in metres, mm, grams and kilograms etc. Boilermaking as a trade is nearly dead, but would be metric.
In the UK all packaging and food sales must be in metric units, but otherwise metrication is self-regulating and more or less voluntary. Because of the vast amount of equipment and tooling which has still imperial units inherent in it, much manufacturing there still uses imperial units. Boilermakers could see either system.
Mar 20, 2017 | Cars & Trucks
The number on the fan control in My 2005 pontiac grand prix and degree are in celsius. How do I change that.
My Buick has a button on the dash that says ENG / MET This changes everything from Imperial to Metric. Even the speedometer so you have to be careful In Ontario our speed is metric 100 is actually 60 miles per hour but if you push this button to imperial you have to adjust your speed to 60 Our signs are all metric.
Oct 16, 2016 | 2005 Pontiac Grand Prix
Can this model be changed fom Metric to Imperial? Thanks Model pedometer HJ-112 by Omron
Why do you want to change it from Metric to Imperial? Omron Pedometer works really fine and I don't think there's any need to change it.
Jul 21, 2012 | Omron Healthcare Hj112 Pocket Pedometer
How do I change from Km to Miles on the odometer for a Rav 4 (2006)?
Disconnect the battery for 90 seconds, then unplugged the cluster.. Then connect the battery with no cluster.. HVAC display changed to metric...
Re-connected the cluster again, display changes to imperial...
The cluster is what dictates what is displayed. It is metric by-default but a US imperial instrument cluster overrides that.
Jun 29, 2011 | 2008 Toyota RAV4
Changing metric to Imperial on Suunto Vector
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
It's in the manual. I did it on mine.
Dec 25, 2008 | Suunto Vector Wristwatch
New Aqualand promaster dive watch JP1010-01L. Temperature currently displayed in C. How do I change display to F.
Called Citizen Customer Service and was told that there is no way to change it. These watches come set with metric or imperial scales from the factory and cannot be changed.
IT SUCKS !!!!!
Apr 21, 2008 | Breitling Navitimer A2332212 G5 431A watch
Bosch Dle 70 Laser Distance Measure 70m Range Metric Measuring Logo
27 people viewed this question
Top Bosch Optics Experts
james laughton
james laughton
ray gallant
Are you a Bosch Optic Expert? Answer questions, earn points and help others
