Question about Maytag Neptune Washer
Maytag Neptune MAH4000AWW - pump removal?
Hi... I think my drain pump is bad or something is stuck in it. It could also be something stuck in the inlet hose. My problem is that I can't figure out how to get the hose/pump out without water going all over the controls. I also can't figure out how to detach the pump from the housing in order to examine it. Any pointers? I already have access through the front panel and rear access panel.
  • Anonymous May 21, 2009
    That's the plan... To take the hose off first and check it and then move on to the tub. Question being, how do I get the hose off without getting water everywhere? I don't want the computer board and other stuff to get wet.
Simply disconnect both hoses and twist the pump to the left to remove. There are two round nubs at the bottom of the white plastic pump housing. These fit into curved slits in the floor of the machine. The slits have a round opening at one end that the nubs can slide in & out of. But check your drainage hose first! I struggled to remove my pump before taking my hose to the bathtub to give it a good rinse. I didn't find anything in the pump but lots of crud in the hose. I'm waiting for everything to dry before I turn it on and see if I fixed it.
Posted on Jan 26, 2010
  • 585 Answers
I found a screw stuck in mine once. Went to all the trouble to take it out and all apart like you're wanting to do. Then I figured out that if I had just took the flexible line off that feeds it from the tub, I could have pulled the screw out with a magnet. Whatever is in yours may be accessible the same way. If the object is non-magnetic you might use a forcreps or needlenose pliers.
Posted on May 21, 2009
  • Bruce Volkers
    Bruce Volkers May 21, 2009
    If you lower the drain hose it should siphon the water from the tub. If it won't flow, there may be a sock in the pump. If that is the case, backflushing from the drain hose, (with garden hose) may dislodge so it will drain.
  • Bruce Volkers
    Bruce Volkers May 23, 2009
    Did you get this resolved?
How to fix the pump in maytag neptune washer
Remove the back panel there are four screws in panel. the pump is acessable on left side facing back. The pump is bad or you have something stuck in the pump.eg.bobby pin, bra support wire, and have found coins in them also. Have towels handy to absorb the water.
Feb 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washer model #MAH4000AWW. Just happened! Water fills then nothing. Wife says it "seems" like it wants to do something but doesn't
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH4000AWW Front Load Washer Washer will not drain.
Sounds like an object is stuck in the pump. Does the pump activate? Does it try to pump out water. Please let me know.
Jul 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer the water will not drain out of it
Check for obstruction in pump located at back of machine. Remove back panel and pump will be located on left hand side.
Feb 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune model number mah4000aww
its your pump.get at it thru the back.it may be blocked or may have failed.a volt meter will tell you if its getting voltage.if so should drain,make sure on about spin setting to check.ive had to replace the pump on my neptune
Dec 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAH4000AWW won't drain
you might do it yourself , looks like the DRAIN PUMP MOTOR is clogged or block with something , needs to be removed and clean . open the panel to access inside washing machine , follow the DRAIN HOSE till you see it attached to a little motor ,remove drain hose from motor , take the motor out and check the impropellers and clear out any debri thats blocking motor to function when it reach the RINSE CYCLE , HOPE you can do it and good luck
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
I HAVE A MAYTAG NEPTUNE WASHER, MODEL NO. MAH4000AWW. WASHER WILL NOT SPIN OUT. WATER STAYS IN TUB. I DON'T KNOW WHICH PART NEEDS TO BE REPAIRED, COULD IT HAVE ANYTHING TO DO WITH THE CONTROL BOARD?
It is the drain pump and motor assembly that does not remove the water from the tub. Althought it spins, water is not sucked out of the tub. Try replacing the drain pump and motor assembly. Part no. 22003059.
I did and my washer works well now.
Bill P
Herndon, VA
Mar 30, 2008 | Washing Machines
Washing Machines Logo
1,213 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
