Question about ASUS Computers & Internet
Icon in My network places of LAN connectin disappeared
My onboard LAN is not working. My OS is unable to recognise any network adapter connected.
  • Chris Hingee
    Chris Hingee May 11, 2010
    Re-install the LAN driver.
    Check the Device Manager to see if it is installed and enabled.
    Brigadier General:
  • 10,406 Answers
You have a "root-kit" computer-virus on your keyboard.
It is preventing your copy of Windows from showing anything in the "Network Connections" display.
From a different computer, search for "sysinternals rootkit revealer". Download the software to a USB memory-stick, and then move the USB device to your computer, and run the root-kit revealer, to remove the computer virus.
Posted on May 21, 2009
Unable to connect wireless LAN
It would help if your supplied the Asus Model and the OS you are using. Is your Wireless adapter enabled in the Device Manager? Are ALL the Windows and Asus updates current? What does the software indicate when you try to connect? In the Tray Notification Area , open the network icon, in Network and Sharing Center, what does it say? If you click on Connect or Disconnect and select your Wireless Network what happens?
Mar 06, 2013 | ASUS Computers & Internet
Computer won't recognise ethernet connection from router
I don't know the make. model, of laptop or your OS? Open network connections, is it enabled? Is there a Network Icon in the Tray Notification Area? You really do not need a Disk to connect. Just plug in the ethernet and boot the machine.The computer should ID the connection, if it enabled and working properly. If not open Device Manager , Network Adapters and enable the ethernet adapter.For further assistance respond to post.
Dec 18, 2012 | Computers & Internet
Asus p5g41t-m csm motherboard is having LAN problems
Go to Control Panel and Device Manager. Check Network Adapter for normal. If all appears normal go to Network and Sharing Center to setup a connection. If still unable to make a network connection then download the LAN driver for Windows 7 from ASUS at this link and install it.
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=22&m=P5G41T-M&os=&hashedid=FaRsjolgBLJKq49g Then reboot and try your connection again.
Dec 03, 2011 | ASUS P5G41T-M/CSM Motherboard
I am unable to access the internet connection on my system as some Adapter is not recognised by the system. Please tell me what is it
first you have to check whether the LAN drivers are installed properly to find whether LAN card is installed properly right click my computer then properties then hard ware then device manager then in network adapters do you see a circle with yellow color uninstall and reinstall the LAN driver then restart your system then click start run and type cmd and click enter then type ipconfig /release after ipconfig is release type ip config /renew then type ping 192.168.0 1 you will see the files pinging it means the computer is connected the modem if not pinging go to network connection in your control panel then right click you default device then click networking then select internet protocol and click properties make sure obtain an ip address and dns is marked if not mark them then save and exit
Apr 28, 2011 | Gigabyte Computers & Internet
I have aa ACER X3200 and the net work adapter will not recognize the LAN plugged in. The LAN source is active and works on other computers I have.
Check the Network Connections (in control panel) to see if the LAN connection is enabled. If not there, you'll need to setup a new network connection. If it is there, right-click the connection icon and choose enable.
You can also check the Device Manager to see if the network adapter is listed and working without errors.
Oct 03, 2009 | Acer Aspire X3200 PC Desktop
I HAVE A BUILT-IN NETWORK ADAPTER IN MY COMPUTER FUJITSU, M0DEL FMV 6000CX2 HOW CAN I INSTALL IT AND MAKE IT WORK.
Normally it is automatic enable.
U can see a local network connection (LAN) icon appear under network connection. The icon will show u unplugged if u did not connect to any network or devices.
If u did not see the LAN icon, then u need to check under device manager whether there is any missing driver.
Mar 10, 2009 | Computers & Internet
Teaming Intel Card
That NIC is end of life ...obsolete
Mar 02, 2017 | Computers & Internet
Lan Network Problems
Hello: What I would say is: go to microsoft update and make sure you have all the updates for your OS.
Then; read the posting (below) from someone who had the same issue:
stacemarie wrote: "XP SP 3 updates some networking sharing system LAN files that cause some configurations to become unaccessable on the workgrouped networks. We cannot - even ping - the network addresses after installing - so it was an uninstall and do a system restore to get to the original good working state of the clients.
Microsoft needs to come up with a patch to fix this as we are seeing more and more networked clients having these connection and sharing problems."
Do you understand the above?
Let me know if you do not know how to unistall SP3 and do a Restore...
Jun 24, 2008 | LanReady LA1000+ Network Adapter
Lan Problem
Goto control panel and work your way through the network Set-up Wizard.
If this is not a separte Icon in control panel then look under "network Connection" Icon.
Feb 26, 2008 | D-Link DFE-530TX+ Ethernet ED100W Network...
Computers & Internet Logo
96 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
