Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
On my pt-50lc14 hdtv my screen is stuck on this message, 5v eeprom), 3.3v (gc2), tv-factory mode
After replacing the lamp and cleaning out the filters and eye light lens and putting the tv back together. I turn on the set and the power light blinks yellow and the lamp and temp lights blink red simultaneously with the yellow power light about 8 times. After that the set turns on with a message that says Choose a language, (1) English (2) Spanish (3) Francias. When I try to select number (1) my remote blinks red and I'm unable to choose a numeral. After powering off with remote and back on I get a different message that says, 5v eeprom) 3.3v (gc2) tv-factory mode. This screen stays the same even if I repower off and back on. If I unplug and try again it is the same. What did I do wrong? What is the problem, How should I fix this? Is it worth fixing?
    Scholar:
  • 102 Answers
Have you tried any of the reset commands?
Try these....please let me know the result:
Method 1
1. Unit power must be ON and unit must be in STOP mode.
2. Press and hold [CH UP] and [CH DOWN] ON THE UNIT for over five seconds. The unit will turn off.
3. Press [DVD POWER] to turn the unit on.
Method 2
1. Press [STOP, TUNE MODE] on the main unit and [>10] on the remote control at the same time for about 3 seconds until the message "Initialized" disappears from the television screen.
2. Turn the unit off and on again.
Method 3
While the unit is off, press and hold [VOLUME +], [OPEN/CLOSE] and [POWER] on the main unit at the same time for more than 5 seconds.
Method 4
While the main unit is on, press [POWER] on the main unit for more than 4 sec. (All the indicators will blink twice when the main unit is reset.)
Another possibility is to unplug the power cord......wait 30 minutes and plug it back in, possibly repeating the steps above. (Method 1 should reset the unit but maybe trying each of them may be necessary until it is reset.
The message appears to be one that displays when the unit is in a setup mode.
Thank you for your reply.
Posted on Jan 02, 2014
  • ebashur Jan 14, 2014
    That probably is not the problem. Coming from the tuner PCB there is two pin connector that can plug into one of two locations. You probably plugged in into the wrong location.
4 Suggested Answers
SOURCE: No Picture - blinking red light.
buy a new tv
Posted on Jan 09, 2008
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
SOURCE: Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Posted on Apr 08, 2009
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
How do i reset the lamp hour on my panasonc PT-50LC14, the replace box keeps coming on thanks john
all you do is turn your tv on. if mesage appears then push exit on the remote, then hold the volume down button on the tv , and at same time hold split button on the remote for 5 to 10 seconds. then a message will appear that lamp meter has been reset to 0.
Mar 08, 2011 | Panasonic PT-50LC14 50" Rear Projection...
Reset lamp timer panasonic tv
PT-43LC14/PT-50LC14/PT-60LC14.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down SPLIT PLAY button on the remote until a message appears on the screen that the lamp timer has been reset.
Good luck
Note: I got it from here: http://www.dlplampguide.com/tyla1000.html
Dec 13, 2010 | Panasonic PT-43LC14 43" Rear Projection...
How reset the lamp in panasonic tv PT-50LC-14 ?
While holding Volume Down button on TV Front and press and hold Play/ PIP button on tv Remote at same time for 6 or more seconds to reset lamp hours.
TV will show lamp reset message on screen.
Thanks.
May 02, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
Apr 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
184 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
