Question about Magellan Triton 400 Handheld GPS Receiver
Locked up with fatal application error on display
When I power on my Magellan triton 400 GPS unit. A fatal application error panel comes up and the unit freezes.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 154 Answers
It is too complicated to fix yourself. If the unit is out of warranty, the JungleGhost at jungleghost.com has a repair service. Go to http://www.jungleghost.com/repair_service.shtml
Posted on Jul 07, 2010
When i turn on mt magellan triton 400 the first screen comes on and that is all and ii cant turn it off
Definitely an internal memory error. The unit has to be reflashed. If under warranty go to Magellan.
Jan 09, 2011 | Magellan Triton 400 Handheld GPS Receiver
Magellan triton 400 fatal application error gps doesnt work anymore when i open it it give me that error and i cant do any thing with it
What you have to do when your gps device comes up with such a message is for you to reset your device. First check that the battery is properly charged, then you reset it by pressing the reset button that is on it. If that does not do the job. then you have to do the back up restore solution.
To do that, you have to connect your device to the computer that has its software, then you browse out the device using the computer page, then you format your device by right clicking on the device from the computer page, then you select format, do not use the quick start, format it normally, that way the whole software and applications on the device will be wiped out, then you reinstall your software back on it and try to load maps on it. After doing that, your device will work perfectly fine once again.
That should do the job.
Dec 30, 2010 | Magellan Triton 1500 GPS Receiver
MAGELLAN TRITON 400 RECEIVES NO SAT SIGNAL
Sorry but you most likely have bad components in the GPS + ANT on the motherboard.
If the unit is in warranty .. return it to Magellan
Oct 03, 2010 | Magellan Triton 400 Handheld GPS Receiver
Magellan Triton, continues to get fatal application error. What can be done to correct this situation?
Your problem stems from a corrupt software file in the internal memory of the GPS. Unfortunately, the problem is too complicated for you to solve. I really do not know of any people beside Magellan that repair the 200. The Jungle Ghost repairs 300 400 500 1500 and 2000's and maybe he can help you out. Check with www.jungleghost.com
Aug 23, 2010 | Magellan Triton 200 Handheld GPS Receiver
When turned on the triton 400 gps will read; internal error.... your triton has encountered an unexpected error and must shut down....please wait while your data is saved.
This problem is caused by a corrupted software file on the internal memory. The chip has to be reflashed. If under warranty return the unit to Magellan.
Jun 19, 2010 | Magellan Triton 400 Handheld GPS Receiver
When I power up my Triton 400 an Internal Error message window shows up and then the unit shuts down after a few seconds. It fails repeatedly. Is there something I can do to be able to use my GPS again ?
Hello :
First try new batteries . If that didn't work , then I recommend you to reset your Triton . Resetting can solve errors and faults that occurs in your device .
Try this for resetting :
1:Using the stylus, tap "Main Menu" and select "View."
2:Tap "Settings," and select "Restore Factory Settings." You will be given the option to confirm this action. Be sure that you want to reset to the settings that the GPS was built with. This action is irreversible.
3:Tap "Confirm," and the unit will begin to reset.
For that you need a thin object (such as a paper clip)
Don't use this method on other Magellan models .
PLEASE DON'T FORGET TO RATE !
Apr 14, 2010 | Magellan Triton 400 Handheld GPS Receiver
Magellan Triton 300 giving Fatal Application Error!
This is a problem with the internal memory files. They have been corrupted It is too complicated to fix yourself. If the is out of warranty, the Jungle Ghost at http://www.jungleghost.com/repair_service.shtml has a repair service.
Jan 20, 2010 | Magellan Triton 300 Handheld GPS Receiver
Magellan Triton 400 Locks up
Nov 07, 2009 | Magellan Triton 400 Handheld GPS Receiver
Magellan triton 400....fatal error?
Jenn,
OK .. take out the SD card. Then power up the unit and do a MENU>>VIEW>>SETTINGS>>MEMORY.
First do a CLEAR MEMORY and after that is completed do a RESET FACTORY DEFAULTS.
Now you unit will be ok and you can place your SD card back in the unit. By the way .. never use an SD or SDHC card smaller than 4GB on the unit.
JG
Jul 26, 2008 | Magellan Triton 1500 GPS Receiver
Magellan Triton 400 Handheld GPS Receiver Logo
552 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
