Question about Barnett Outdoors Barnett Vortex Lite Youth Bow
Arrow rest installation - Barnett Outdoors Barnett Vortex Lite Youth Bow
How to factory rest zenith plasma tv
Here give this a try and hope this helps.
  • Press the "Menu" button on your remote control. Use the up and down arrow buttons to highlight the video option. Press the arrow that points to the right to select the video option.
  • Use the up and down arrow to highlight the video reset option. Push the right arrow button on the remote control to select video reset.
  • Press the right arrow button on the remote control to return the video to original values.
Jul 06, 2014 | Zenith P60W26 60 in. HD-Ready Plasma...
Tip
How to remove and reinstall a clutch on an a/c compressor
The AC compressor continued to turn even after I pulled the 12-volt supply wire to the unit. The AC compressor exhibited no unusual symptoms that would explain the locked clutch, there was no bearing failure, no unusual noise, On the contrary, the AC continued to work properly. The Jaguar cooled as good or better than the other cars I currently own, all of which have original factory 134a AC systems. uses the GM A6 compressor, a common compressor used by a variety of General Motor's cars I was not about to disassemble a perfectly working AC system because of a defective clutch. The project starts by removing the hood. Clearance in the Jaguar engine bay is non-existent. In addition, the AC compressor is located 3 inches from the radiator top support. it is possible to do this with the hood on you will regret it. The objective is to replace the AC clutch on the car. Remove the AC compressor's front and rear bolts only. Lift the front of the compressor up to clear the top radiator support. Do not depressurize the system or remove any hoses.
Remove the center 9/16-inch nut from the compressor shaft. A special clutch holding tool is not needed if an air impact wrench is used.
install the clutch removal tool. The clutch is "press fit" to the AC compressor front shaft.
Instead of a clutch holding tool, I used a bar resting on the engine (blue arrow) to hold the tool removal nut while I turned the center stud that forces the clutch off.
The pulley is now completely visible. You will need a large snap ring pliers to remove the snap ring that secures the pulley.
Notice the towel below the compressor. Snap rings (red arrow) have a habit of flying off the pliers and disappearing forever into the engine. You are farned
The pulley is a zero clearance fit to the compressor nose. If you are lucky it will slide off by pulling on it. You will probably not be lucky. I used a puller to remove the pulley. Be careful here. You must identify what the puller can and cannot push against. The center compressor shaft must not be used as leverage to pull or push any component not on the compressor shaft. A 1 1/8-inch, 1/2-in drive socket (red arrow) will fit over the center shaft and rests on the compressor nose cone. This is my leverage point. I taped a large washer (blue arrow) to the socket to provide a contact point for the puller.
Attach puller jaws in the pulley groves and place the modified washer to rest against the nose cone. Slowly tighten the puller to remove pulley.
Locate and secure pulley key. If the key stays on the compressor shaft, do not remove it. An even bigger snap ring secures the coil assembly to the compressor. Remove the snap ring.
Remove coil assembly.
The clutch release springs (blue arrows) also appear to be in working order.
Testing the resistance of the coil assemblies indicate that they are within specs. The old coil pack reads 4.8 ohms.
The rebuilt coil pack reads 4.5 ohms.
In removing the clutch it appeared the coil was permanently energized. The clutch removal tool had to forcefully pull the clutch from the pulley. I was not about to put this coil pack back on. I cleaned the contacts on the rebuilt unit prior to installation.
Gently clean the nose cone remove any surface rust. the clutch bearing rides on this surface, it must not be damaged.
connect coil pack to compressor and install. Make sure the coil pack is attached properly to the electrical connector. There are three indicators on the rear of the coil pack that must match the corresponding holes in the compressor body (red arrow). Install big snap ring.
Clean pulley surface and install pulley. The bearing might require some slight persuasion to slide onto the nose cone. Use a drift (red arrow) that contacts the inner ring of the bearing only. Tap gently until the pulley bearing seats.
Install second snap ring. Make sure that the snap ring seats fully in the shaft grove. Tap the snap ring fully into the groove with a screwdriver if necessary. (red arrow)
Clean clutch mating surface and install clutch to the compressor. Note position of shaft key and corresponding clutch key slot. (red arrows). Make sure they line up before installing clutch to compressor shaft.
use the clutch installation tool. The front of the tool (blue arrow) screws over the threads of the exposed 9/16-inch shaft stud (yellow arrow). The nut then forces the bearing (red arrow)against the clutch face, forcing it onto the compressor shaft. One side of the bearing rotates with the nut to reduce friction as it forces the clutch onto the shaft. Note that the forces all act on the compressor shaft, not against it.
Hold the center bolt while tightening the nut down.
You are looking for a pulley clearance of .010 to .015. If you inadvertently create too close a gap, put the clutch puller back on and pull the clutch out accordingly. Replacement and or rebuilt parts are rarely perfect. You will probably get different readings at various locations around the circumference of the clutch. If the closest gap is .010 or more and the largest gap is .015 or less you are OK.
Install 9/16-inch self-locking nut and tighten. If a clutch holding tool is not available, then finish tightening this nut after the compressor belt is on and the clutch energized. This nut does not hold on or impacts the position of the clutch. It appears to be a safety precaution just in case the press fit clutch somehow comes off the compressor shaft.
Install compressor to engine. Tighten 4 bolts to engine bracket. Connect electrical connections to coil assembly. Install belts.
Turn on your vehicle and let there be cold air, good luck sorry illustrations wouldn't load to this format
on Mar 05, 2011 | Jaguar XJ12 Cars & Trucks
How do I attach the arrow rest to the bow
The arrow rest must be aligned for the proper knocking point. There is a 12 dollar tool for this at most sporting goods store called a bow square.
Feb 06, 2014 | Man Kung Archery
Toner is replaced in samsun scx4521 but toner reset wants password what is it
Enter in the service mode: Press:
Menu - Copy - Left arrow - Right arrow - Menu - Right arrow
On the screen displayed Tech select Clear data and select Counter clear.
Mar 30, 2013 | Samsung SCX 4521F All-In-One Laser Printer
Drop away rest won't stay up when nocking arrow
is it automatic or is it controled by a string atached to the rest?
Nov 05, 2012 | Quality Archery Design Archery
I can't solve it no matter how I try Puzzle 69 nintendo ds blocks
Sorry, that is why they call them puzzles. All the advice I can offer you is to be persistent. You will be rewarded with the feeling of accomplishment when you succeed in finishing the puzzle.
Apr 03, 2011 | Nintendo 50 Classic Games for DS
My ipod touch 4 wont work! it shows the # symbols (usb, arrow, itunes), and it doesnt do anything else! pleaseeeee help! Thanks.
You must have bought a new iPod!
The screen is simply telling you to connect your iPod to your computer. (You should have iTunes already installed, if not you can download it, and install it for free from the Apple website).
Once it is connected, iTunes will pop up, and the rest of the set up will be simple!
Feb 20, 2011 | Apple iPod touch
Arrows seem to dip and rise to the target
the spine of the arrow seems to be off a bit. The spine is the stiffness, check a archery chart for your bow draw weight and suggested arrow spine.
Dec 18, 2009 | Saunders Archery Sport & Outdoor - Others
How to creat new folder on desktop using keyboard winthout any supporting software installed in widows xp
assuming your desktop is selected the little button on the right of you space bar between the Alt and Ctrl keys will bring up the right click menu (Context Sensitive Menu)
Scroll down the menu using your arrow keys to "new"
Press the right arrow key
Select Folder
Well the rest you can work out for yourself - its the easy part :P
You can select your desktop by pressing Alt-Tab and selecting your desktop
If this helped you at all please vote
Oct 06, 2009 | Computers & Internet
I need help installing speakers and the rest of the audio can some one help please
Here you go buddy:
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=45&NAVDISP=homeav
Look at the middle where it says Connectivity then click on the second red arrow where it says Sony Hookup/Connection.  Then just choose what type of system you got.
May 10, 2009 | Sony STR-DE685 Receiver
Barnett Outdoors Barnett Vortex Lite Youth Bow Logo
195 people viewed this question
Top Barnett Outdoors Archery Experts
Tom Chichester
Andre De Beer
Andre De Beer
Level 1 Expert
pbickwermert
Level 1 Expert
Are you a Barnett Outdoors Archery Expert? Answer questions, earn points and help others
