Question about Dual XDMA550BT CD Player with Bluetooth and USB Control for iPod and
Blue tooth not working - Dual XDMA550BT CD Player with Bluetooth and USB Control for iPod and
Hi fixya, this rajendran from tamilnadu, i have acer 4736z. how to switch on blue tooth?. Pl help
If your blue tooth working normal just double click your blue tooth icon on screen to activated your blue tooth.
Regards
Feb 04, 2011 | Computers & Internet
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
Bluetooth not working in sony W580i phone
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooyh not working
the blue tooth has a solution.
It is in two ways.
Either the the blue tooth is not pairing well with other devices,
or
The blue tooth is corrupted.
When pairing phones together, make sure you pair the phone properly before you can use the blue tooth with other phones, because if you don't pair properly with another device, you will not be able to send or receive any data.
If the blue tooth is corrupted all you need to do is to flash the phone, that is the only way to restore the blue tooth back to be working.
Have a nice day.
Mar 15, 2010 | Nokia N70 Cellular Phone
On my ps3 bluetooth scanning for a ps3 headset its
Make sure that your blue tooth is in pairing mode when the sysytem is scanning.(refer to blue tooth headset manual for intrustions)
I hope i have helped and I hope it works!!
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
I have a sanyo katana , will all blue tooths work on this phone?
Most of blue tooth will work with this phone, but to be on the safe side. Go to blue tooth manufacturer website and check if their blue tooth is compatible with your device.
Nov 14, 2008 | Sanyo Katana® II Cellular Phone
Motorola Razr 2 V8 blue tooth will not power on
my motrola v8 b tooth can b powered on , and it can recieve data but i cannt send data to any blooth tooth device , the send botton in the last not working, cn u tell me why.....
Oct 18, 2008 | Cell Phones
Blue tooth adapter and hs850 headset on my computer
Yes, you need the blue tooth driver. The one that comes with your blue tooth "toggle". Although my laptop said "blue tooth compatible" I still needed a toggle. They are fairly cheap to buy and go into a USB port.
Sep 17, 2007 | Motorola Mobility HS850 Consumer Headset
MY BLUE TOOTH ISN'T BEING READ BY MY PHONE...
Delete the headset from your phones previous or known devices and turn off phone then back on again and try pairing again. If still same could be faulty phone, but if you can try headset on somebody elses phone to rule out headset.
Jan 23, 2007 | Audiovox SMT5600 Smartphone
Dual XDMA550BT CD Player with Bluetooth and USB Control for iPod and Logo
32 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Michial Gueffroy
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
