Question about Maytag Dryers
How do i remove the top of a maytag LDE9304ACE dryer?
There is obvious heat damage on the lower left side of the back of the dryer--not quite scorch marks, but the paint has degraded, and the paint has peeled off the wall behind it. I need to get in there to see what's up, but don't know how to lift the top to start opening it.
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Need to repaint bubbled and peeling paint on top of dryer
The choice is yours. Money often motivates these decisions. If the model number you have this listed under is correct, the top panel price is roughly $108 to $160 depending on the color you need. White or Bisquit is the cheapest, while Pewter is the most expensive. If you wish to replace it, appliancepartspros.com carries it for the cheapest price.
If you wish to paint it, remove the panel from the dryer first by locating and removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off. This will allow you to work on it in a more convenient location and avoid any overspray from paint on your appliance. Make sure you clean the surface throughly to remove anything that may have caused the paint to bubble and peel in the first place (Ospho is commonly used to clean metal surfaces in preparation for painting - clean AFTER you sand). I would sand with a fine grit sand paper or emery cloth to ensure you don't leave any surface scratches. Prime the entire panel to provide a good surface for the new paint to adhere to. Once the primer is dry, apply a couple of good coats of appliance paint. If you have questions, please let me know. I hope this helps you.
Posted on Sep 06, 2009
Testimonial: "Very helpful and quick response. My Dad passed and I need another source for knowledge............."
Electrolux Dryer quit and has a code E 63
Mark, the heating element is underneath the drum, on the left (as facing the front of the unit).
Per the Dryer Tech Data Sheet:
E63 Error Code indicates: [Fault] Heater to Earth Ground [Possible Fault Conditions] Heating element or wiring defective [Possible Solutions] Check heater coils and connections for short circuits to the cabinet. Replace heater and/or wiring and retest.
To open the cabinet is quite difficult, speaking as a non-professional. There may be easier methods than what I used, but I was successful. First I removed all the screws from the back (there are many). This got the top and the back panels removed. The left side (where I could see the heating element was) gave me considerable trouble until I realized I had to remove the door trim to reveal one last screw. Finally got the side off and swapped out the heater. Much much vacuuming for me. I am still trying to figure out how to clean out the bottom of the duct (underneath lint filter), but that's another post.
Also, just in case you don't have the manual and/or need to order parts, I will include a link.
http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Dryer-Parts/model-EIED55HIW0/1412/0151200
For some reason, the Sears Parts Direct website lists the dryer as a Gas dryer, which it obviously isn't, as the part in question is very clearly an electric heating element. Hope this helps.
-Nick
Mar 03, 2014 | Electrolux EIED55H Dryer
Maytag gas dryer bravos mod#MGD6400TB0 no heat
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct
May 11, 2012 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
Our dryer runs but doesn't heat. I have checked the obvious things but have not got into the ignitor etc. In order to access the burner etc. on this model do you have to access through the top. Older...
dont forget about thermal fuse on back of dryer white plastic with two wires can jump out for testing see if you get heat if so replace thermal fuse and clean venting adn venting flapper for opening and closing .... if no heat tthen open lint screen on top of dryer remove two phillips screws pull lid forward from back corners towards u and lift lid up remove front screws should be two 5/16 screws on in each corner and door switch harness connected lift front upwards and to the right remove drum belt tensioner bottom right side .. release belt remove drum set out of the way ... plug in dryer watch ignitor in burner tube bottom left corner should glow redish orange then a click and then a flame
no glow aslong as thermal fuse has been checked bad ignitor....
if glows and no click replace flame switch black and silver box on left side of burner tube
if glows and clicks and no flame replace two black round coils on top of gas valve
Jan 28, 2011 | Dryers
Our dryer stopped working. what can be the problem
thermal over heat switch is located on lower left side of drier , youmust remove front of drier this is under the drum in lower left side. it has two wires attached.remove wires and test with ohm meter if no reading on meter it is bad.
Nov 17, 2010 | Maytag MDE308DAYW Electric Dryer
How do I replace the heating element in Maytag Dryer SDE2606AYW Serial# 12508837EN
1.Unplug the Maytag dryer from the dryer electrical outlet and pull the dryer away from the back wall.Use a putty knife to press in the locking clip between the front and top panels.While pressing the clip in with the putty knife,lift the top panel up to unlock it from the clip.Raise the top panel into the service position allowing it to rest on the back hinges.
2.Locate the door switch connection on the inside front right corner of the Maytag dryer.Press the locking tabs in with your fingers and pull the wiring harness away from the door
switch.With a Phillips-head screwdriver,remove the screw on both inside corners that secure the front panel to the sides. Lift the front panel up and away from the dryer.
3.Use a Phillips-head screwdriver to remove the four retaining screws that secure the drum bulkhead to the front of the side panels. Remove the bulkhead from the dryer.Reach under the drum and pull the idler pulley to the left to release the belt tension.Remove the belt from the motor and idler pulley. Lift the drum up and out of the dryer unit bringing the belt with it.
4.Remove the two screws that secure the heating element to the rear bulkhead with a Phillips-head screwdriver.Disconnect the heating element terminal wires by grabbing them with needle-nose pliers at the wire leads and pulling them off of the terminals.
5.Place the new Maytag dryer heating element into the dryer and slip the wire leads over the terminals.Secure the heating element to the rear bulkhead with the retaining screws.Lift the drum and belt and place the drum back inside the dryer cabinet.Route the belt around the motor and idler pulley.Shift the idler pulley back to the right to apply belt tension.
6.Reattach the front bulkhead to the dryer using the four retaining screws.Position the front panel into place and secure it to the sides with the retaining screws.
7.Bring the top panel back down and push the front corners in to engage the locking clips.Push the Maytag dryer back into its working position and plug the power cord back into the dryer electrical outlet.
Aug 28, 2010 | Maytag SDE2606 Electric Dryer
How do you replace the heating element in a Maytag PYE-2300
Unplug the dryer cord.
Use a putty knife to release the 2 spring clamps holding the top lid to the front panel. They will be about 2 inches in from the right and left sides where the top meets the front.
Raise the top lid and fold it towards the rear of the dryer.
The heating element will be in the back left corner.
Remove the hi-limit thermostat on top of the element. Remove the element retaining screw and remove the element.
You should replace the hi-limit thermostat also.
Dec 14, 2009 | Maytag Dryers
I have a Maytag MGD5800TW Gas Dryer. It does not heat up. What should I check?
First, Remove small plastic tab on front panel of dryer lower left corner. Start the dryer on regular cycle and observe what happens through hole. You need to know if ignitor glows orange. If you do not see the ignitor glow orange, replace the ignitor. If seeing full orange of the ignitor, do you hear a clicking and see the flame light?
Leave the dryer cycling while observing. When the dryer heats to temperature the flame will shut off. If the gas valve coils are bad the next thing to happen will be that the ignitor will glow orange again, the valve will click again but the flame won't light.
If the gas valve coils prove bad, based on the observations above, follow the procedure below to replace the coils. If NOT, come back with the results of your observations.
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Remove lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components will be on left. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
Reverse process to re-assemble.
Sep 20, 2009 | Maytag Dryers
Maytag gas dryer. Belt broken. How do I open and replace it?
On the right front and left front of the panel there are 2 phillips head screws. They are about 4 inches up from the floor. Remove these 2 screws,lift the door panel out then down to dislodge the top clips. Remove the door switch wires and set the door aside. Remove 4 screws from the front drum support. @ on the right,2 on the left. Remove the drum support.Install the belt around the drum. The smooth side of the belt goes against the drum. Re-attach all the parts in front. Remove the belt access panel on the rear of the dryer on the bottom right side facing the dryer to arrange the belt around the motor pulley and tension roller.
Aug 21, 2009 | Maytag Dryers
My maytag electric dryer is not getting hot.
It sounds like the element shorted out and caused more damage to the unit. Remove and check the heating elment, thermal fuse (located near element), and timer. The timer will be hard to test if you don't have a meter. I would suggest that you check the element first. This is probably your main problem.
Apr 18, 2009 | Dryers
Heating problem
Unplug the dryer.
Take a putty knife and insert it at the top of the front panel just below the lid and push the 2 clips in.They are about 2 inches in from the right and left sides.
Raise the top lid towards the rear of the machine.
Remove 2 screws on the inside top corners of the front panel. Remove the front panel.
Remove the belt. Remove the drum.
The heater will be on your bottom left.
Apr 12, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Dryers Logo
20 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
