Question about Canon PIXMA MX310 All-In-One Printer
MX 310 printer
My MS 310 printer always says ink level low when I use a remanufactured cartridge, is there a way to correct this or do I need to use only OEM cartridges?
    Brigadier General:
  • 10,406 Answers
Some "remanufactured" ink-cartridges are just "refilled" cartridges,
and the company that refills them cannot "reset" the electronics inside the ink-cartridge to report that the ink now is "full".
So, just use the cartridge until you notice that the ink has gone empty.
Posted on May 21, 2009
Can't seem to find how to put ink into my canon mx 310 printer
I'm assuming when you said "fine catridge" you meant FINE cartridge. FINE is an acronym for the Canon Ink Cartridges. Anyhow, plug your printer into the electrical outlet and turn the power on. Wait about 1-3 minutes and open it up and the Ink Cartridge holders should move to the left for you to properly insert your Ink Cartridges.
Jan 31, 2013 | Office Equipment & Supplies
Pixma 320 always says Black ink low, not. Just put anew one in and cleaned all nozzles
I had the same problem , couldnt rectify it and im afraid i had to buy a new printer
Sep 23, 2012 | Canon Black Pixma Mx 320 High Quality...
The canon 310 MX is not able to accept new ink cartridges error 6000
if you purchased a canon 310 mx and if it is new..contact the supplier about it.So that they can instruct you how to fix it..Good day
Dec 02, 2011 | Canon PIXMA MX310 All-In-One Printer
New ink cartriges in MP350. Still saying check ink. Why?
If you are using remanufactured cartridges, the low ink warning is normal. Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. Unfortunately, when the cartridge remanufactured the cartridges, the chip is unable to be reset. Here is a link that may help you bypsas the warning for Canon printers:
http://swapink.com/Merchant5/merchant.mvc?Screen=caninst
If this does not help, there may be a setting in your printer preferences where you can disable the ink level indicator.
Mar 15, 2010 | Canon Office Equipment & Supplies
When we do a fax test, we get clear print; when we try to print documents nothing appears, altho it goes thru all the right sound motions
Sounds like your colour cartridge is empty. Fax test will pull from black only but documents sometimes use a combination of colours in order to print out black. I suggest checking your ink levels - instructions for windows;
Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low Check ink levels
Mar 05, 2010 | HP Officejet 5610 All-In-One InkJet...
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
Can one reset the Lexmark P6250 printer refilled cartridge?
No, you can usually tell your printer to "ignore ink levels" when it gives the ink low warning on your computer screen. As long as they print just keep printing until they run out.
Dec 28, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Hp 5150 deskjet says that it is low on color ink
The low ink warning is actually normal for remanufactured cartridges. Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. Unfortunately, when the cartridges are remanufactured, the chip is unable to be reset. The prints should still be the same quality. You can either press the "Resume" or "OK" button to continue printing, or go into your printer settings and manually disable the ink level indiactor.
Feb 07, 2009 | HP DeskJet 5150 InkJet Printer
How do you check ink levels
Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
Nov 23, 2008 | Office Equipment & Supplies
Reset mx 310
This really worked with my MX 310:  http://www.fixya.com/support/t378057-reset_ink_levels_canon_mx310
Jul 03, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
431 people viewed this question
old marine
old marine
