Question about Sportcraft Arcade Hoops With Electronic Score Board
Espn midnight hoops
I need instruction manual!
Do The ESE ESante Baby Lock hoops fit the ESI ESante Baby Lock machines
The Babylock Esante ESE1 and ESE2 hoops are not compatible with the Esante ESI1 or ESI2 hoops. The Babylock ESI1/2 used the same hoops as the Brother PC7000 and PC7500. The ESE1/2 use the hoops that are compatible with the Brother PC6500 and PE700 series embroidery machines.
I wish that I had better news for you. This site has hoops for sale for both the ESI1 and the ESE1: http://www.allbrands.com/categories/871 . If you need hoops for either machine, use the compatibility data on each machine type to help you find more vendors that may have the embroidery hoops.
Jul 30, 2015 | Baby Lock Esante
Instruction manual for Grand Hoop
Try this
http://www.ehow.com/how_7807598_use-pfaff-grand-hoops.html
Mar 11, 2014 | PfaFF Sewing Machines
How do i calibrate the hoops on a baby lock emp6
This is a translation of instruction from the Service Manual for the Brother PR600, the twin of the Babylock EMP6. I will testify this works because I just did it to stop the insanity of my EMP6 thinking everything was a 5x7 hoop. If you look on page 4-36 of the free PR620 manual http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf you will find the same exact set of instructions that are in the PR600 manual. So here are the exact steps to augment the manual's instructions.
1. Turn off the machine.
2. Press all three buttons (start, threader and cutter) and keep them pressed while turning the machine on.
3. Press MAIN BOARD TEST MODE.
4. Press A/D TEST.
5. Put the largest hoop on the machine (7 7/8 x 11 3/4).
6. Press LL.
7. Put the smallest hoop on the machine (1 1/2 x 2 3/8).
8. Press S.
9. Take the smallest hoop off the machine.
10 Slide the arm to where the knob on the arm is when the large hoop is on the machine.
11 The reading on the screen should be very close to the value that is in the LL setting.
12 If not, go through the large hoop steps (5-6) again.
13 Slide the arm to where the knob on the arm is when the smallest hoop is on the machine.
14 The reading on the screen should be very close to the value that is in the S setting.
15 If not, go through the smallest hoop steps (7-8) again.
16 Press close when you have both settings close. They need not be identical but they do need to be no further than 200 away from the screen value.
17 Turn the machine off.
18 Turn the machine back on, load a file, and see if you have the same results that I had; it will show the proper hoops when you press the hoop symbol and it will also center itself in the hoop properly.
You can buy the PR600 service manual online for about $12. However, you have the 620 manual for free and there is really very little difference. I have found the manual invaluable in saving me trips to the shop and doing my own repairs.
Aug 26, 2013 | Baby Lock Sewing Machines
Janome Instruction Manual
Go on the web for janome sewing machines , pick you model and download service manual (pdf form)
May 15, 2013 | SewShop.com Janome Cord - 300E Power Cord
How to setup a rawling softee hoop set
Unfortunately, I couldn't find a manual or instruction guide online. Here is the contact page of the Rawlings website. They should be able to help you assemble it.
Feb 24, 2013 | Rawlings Michigan Wolverines Slam Dunk...
Bernina artista hoop not recognized
Calibrate the embroidery hoop
Note
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
Aug 15, 2012 | Bernina Artista 180
I need the assembly instructions for a sportscraft basketball hoop
Request instructions from Sportcraft. Note spelling of Sportcraft.
Aug 05, 2012 | Sportcraft Arcade Hoops With Electronic...
I need to find out where i can get the instruction book for midnight club 3 Dub edition.
You can order one here: http://www.videogameinstructionbooklets.com/servlet/the-1049/Instruction-Booklet-Book-Manual/Detail
Feb 03, 2011 | Rockstar Games Midnight Club 3 for...
How do I program ESPN game changer remote control
I have the instruction book. What devices are you looking to proggram - type and brand??
Nov 21, 2010 | Televison & Video
Sportcraft Arcade Hoops With Electronic Score Board Logo
386 people viewed this question
Top Sportcraft Toys Experts
ray gallant
Are you a Sportcraft Toy Expert? Answer questions, earn points and help others
