Question about Saeco Syntia Espresso Machine & Coffee Maker
How can I fix my saeco syntia
It leaks. The contraption will not reconfigure to fit back in. It slides in but not the whole way, so it can:t click into place. Hard water display always there. Xmas 2010. If not how, where can I take it?
SOURCE: Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Posted on Nov 07, 2007
  • 4 Answers
SOURCE: Saeco Coffee maker container is leaking
OK, I finally called Saeco. There are about four rubber rings that you need to get. The one for the water resevoir is a big thick black ring and once you get it and look at the new and the old, you can see why it is leaking. Anyway, fixes it no problem.
The overflow in the drip tray? There are two rings in the back of the machine that will fix that problem. Problem? I got them, but haven't put it on there because it very hard to get in there.
Last one, the ring around the coffee puck maker (what do you call that part) It's the piston that catches the coffe and raises up to tamp it down, then holds it as the water goes through. ANyway, big ring around that. If you aren't getting a nice crema on top, that ring will cure that.
I saw get all four, replace them all at once and then descale the coffee maker and be done with it. You'll be working like new in a few hours or maintenance. For most of us, it's been like 3 years anyway, time to do it.
Lastly, when you call Saeco, (Pronounced I found our SA Yey Co) ask for the directions for cleaning out the grinder. Even has notes on how to get it back together with all the adjustments in the right spots.
The rep on the phone says she likes this model better than most fo the new ones.
Posted on Dec 10, 2008
EsWorld
  • 1618 Answers
SOURCE: My Saeco Vienna De Luxe machine leaks water to the
It is possible that the o-rings in the hose fittings are worn out and need to be replaced.
Posted on Jul 19, 2009
SOURCE: saeco syntia - error message 'problems with the
I read your post. Could you explain me this problem?
Me too have a syntia, but I never saw this error message.
What kind of symbol do you see?
bye
F
Posted on Jul 12, 2010
dcramer531
  • 1654 Answers
SOURCE: I have a sauce syntia
The red icon on front is the call for water, is your machine full? If so the majority of the times it is do to a clogged filter (usually a small metal perforated disk) Check to assure it is fully cleaned, for very difficult clogs soak or you can use a safety pin to clear the more difficult holes. It could also be a scale build up issues so you can perform de-scaling of the machine two - three times one every day and
try to draw out the dissolve water and de-scaling solution in steps with 5 -10
minutes interval. This will give more time to the solution to dissolve the sale
build up in your machine. You can also try a reset. remove the water tank.
Remove power plug and keep aside, Now attach the tank back and test after 1 hour so that it is reset. If this does not clear your Icon after making sure the water tank is full. Then a service call will need to be done as there is some issue with either a sensor or possibly the boiler which has to be perfomed by a trained technician. You can find manual and part6s here for the machine
http://www.partsguru.com/SaecoRioProfi.html
Posted on Apr 08, 2011
Why the ground coffee tray won't close?
Try looking inside where the tray goes and see if there are any whole beans inside that might have fallen into the tray area. It happened to me before.
Aug 27, 2014 | Saeco Syntia Espresso Machine & Coffee...
Syntia swims in water in dreger drawer
Syntia is not set to "3 beans" amount or beans used are too large to create enough grounds to make a full 9 grams for a good puck .
The finger guard does not allow enough beans to grind in the timing of the software , common problem.... until the finger guard openings are made bigger or ... the software is re-programmed
Mar 05, 2014 | Saeco Syntia Espresso Machine & Coffee...
I have a Saeco Syntia and a Red Wrench with the #14 came on the display. I have turned on and off and now the yellow thermostat symbol comes up. you can feel it heating up but it does nothing else.
need to tell me when the wrench appears ,at start up ? YES? then most likely "over pressure valve" is broken and machine needs to be serviced by service center to replace the plastic part with a metal parts ,Stop using it or the leaking water will damage the system .
Jan 18, 2014 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia leaking out the bottom
Over pressure valve is broken, near the water pump , stop using it and get it fixed , or you may damage your Computer board
Nov 08, 2013 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia ground coffee chute not working well
The grind on the coffee might be too coarse and instead of making espresso its coming out like drip coffee because the water is running through it too fast.
May 25, 2012 | Saeco Syntia SS Automatic Espresso Machine
Water tank parts for saeco syntia
Don't know where you are but www.dutchwest.co.uk in the UK supply the parts.
Mar 02, 2011 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia - error message 'problems with the water circuit'
bye
F
Jul 11, 2010 | Saeco Coffee Makers & Espresso Machines
Saeco Syntia Espresso Machine & Coffee Maker Logo
16 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
