Question about GE Advantium 120 Convection/Microwave Oven
Removing front grill - GE Advantium 120 Convection/Microwave Oven
Having trouble removing front grill to install filter..removed top screws but grill will not come loose
Just installed a GE Spacemaker - my instructions tell me to remove screws and then slide grill to the left and then remove. Have you tried that?
Jan 05, 2010 | GE Spacemaker JVM1540 Microwave Oven
Message to change filter but unit exhaust up to stack?
Grease filters change from the bottom side of the unit.
Charcoal filter is changed as follows:
To Remove Charcoal Filter
To remove the charcoal filter, disconnect power
at the main fuse or circuit breaker panel or
pull the plug.
Remove the top grille by removing the screws
that hold it in place and sliding the grille to the
left (opening the door makes grille removal
easier). Slide the filter towards the front of the
oven and remove it.
To Install Charcoal Filter
To install a new filter, remove plastic and other
outer wrapping from the new filter.
Insert the filter into the top opening of the oven as
shown. It will rest at an angle on 2 side support tabs
and in front of the right rear tab. Replace the grille
and screws.
Aug 20, 2009 | GE XL1800 1100 Watts Microwave Oven
Changing filter
The grease filter is changed from the bottom of the unit.
The charcoal filter is changed as follows:
pull the plug.
oven and remove it.
and screws.
Aug 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I can not locate my charcoal filter in my GE Spacemaker Profile JMV2070BH02 where is the charcoal filter
Charcoal filter is behind the grille at the top of the oven. Find screws in front or at top of the grille and remove them.  Remove the grille by shifting to one side and pulling forward with the door open.  You should see a slot where the filter is inserted.  Remove old filter and replace with new.  Note which side of old filter is up and position the new one the same way.  The filter sits on tabs at the side and back.   Replace grille and screws.
Jun 02, 2009 | GE JVM1440 Microwave Oven
GE Profile microwave remove top grill
1. Unplug power.
2. Remove two screws holding grille, either on top of the front edge of the outer case or in the grille itself.
3. The grille should lift right out. In not, you may need to pull it to the left about 1/4".
You can download GE owner's manuals and installation instructions here.
Some models have them on top.
Feb 04, 2009 | GE JVM1750SMSS Microwave Oven
Cannot remove the front grill of GE Micro to replace filter
I have a new ge 1540 and needed to remove the grill to install the charcoal filter.
After removing the two screws on top, you need to slide the grill about 1/2" to the left. Then the grill will wiggle loose and can be removed.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile XL1800 Spacemaker Microwave
remove 2 screws that holds the top grills.
slide the filter towards the front of the oven and remove it.
installation in reverse order.
the filter will rst at an angle on 2 side support tabls and in front of th eright rear tab.
reinstall the grille and 2 screws.
Nov 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn air microwave jmv8208bas The light bulb went out. How do I replace it?
From the service manual:
The top full-width grille is removable for service to some components, such as: humidity sensor, oven light, door removal, flame sensor, vent motor capacitor, fuse, control panel, and stirrer motor (some models).
Grille Removal
1. Disconnect power to oven.
2. Remove screws located in front on top of microwave securing grille.
3. Pull outward on the top portion of the grille releasing the tabs.
4. Reassemble in reverse order.
The oven lamp part original number is 4713−001165 but you can get it locally (generics) at hardware stores, appliance parts stores, etc. It's a common 20 watt halogen bulb.
Oct 21, 2008 | Microwave Ovens
How to install charcoal filter in ge microwave md# jvm1870 sk04
From the owner's manual, page 37:
To remove the charcoal filter, disconnect power at the main fuse or circuit breaker panel or pull
the plug.
Remove the top grille by removing the screws on top of the grille that hold it in place and sliding the
grille to the left (opening the door makes grille removal easier). Slide the filter towards the front of the oven and remove it.
You can order new filters by entering your full model number here.
Sep 19, 2008 | Microwave Ovens
JVM1750SMSS CHARCOAL FILTER INSTALL
I just installed a JVM 1540 with the same grille. I removed the two top phillips screws before mounting the oven as I cannot access these screw heads once the oven is installed. It took me about 20 minutes of fiddling with the grille to figure out (no thanks to the manual) that the grille needs to slide to the left to release so you can change the light bulb/charcoal filter.
Nov 06, 2007 | GE JVM1750SMSS Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
320 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
