The top of the air conditioning unit is dented so the fan won't turn.
The top of the outside air conditioning unit became badly dented making the fan unable to turn inside the unit.
    Sergeant:
    Champion:
  • 219 Answers
You must remove the ac from the window and take the cabnet off then bend it back with a rubber malet.If you allow it to run you will burn fan motor .if you need more info let me know hope i helped:)
Posted on May 21, 2009
2003 ford zx2 air conditioning not blowing cold air
Check and see if there is any Ice on the copper line that runs from condenser (outside unit) to air handler (inside) if so you need a charge. You can also make sure the fan is working on the condenser unit outside it should spin when you have the air on. If it is not you have a bad fan motor. there are other things it could be but these you can see.
May 25, 2015 | 2003 Ford ZX2
We have a weather king central air unit mod# WAKA-030JAZ. ser#5339 mo6959417. volts 208/230. compressor rla 13 5/13.5. outdoor fan motor f.l.a.9. mfd 02/05. hertz 60. l.r.a.76. hp1/6 min supply...
I would bet the outside units contactor is bad. This is the device where the two thermostat wire connect outside. If this is pulling in/out as you turn the stat on/off then it is working. I just fixed one yesterday with the same symptoms and found the start capacitors were bad. If they are bulged at the top or bottom then they are bad. Good luck.
Jun 19, 2011 | Weather King Heating & Cooling
I have a york 80 diamond heating and air conditioning unit. When it is turned on air comes out of the vents but it does not feel cool at all. When I check the unit outside it sounds like it is on but the...
Hello, if the compressor is running on the outside unit and the fan is not either you have a bad capacitor or a bad fan motor, if the fan starts with a push then your capacitor is bad, if it does not the motor is shot.
Jun 16, 2011 | Heating & Cooling
Fan on the outside unit is not running
Fan motor is dry or going bad try to lubricate it and see if that frees it up. If not you will need to get a new fan motor.
Oct 09, 2009 | Goodman CKL36AR36 Air Conditioner
Lennox air unit not blowing cold air
your fan motor outside is going bad, have a service company change it out for you.
the motor stopped working and that overheated the compressor shutting it down on thermal cutout, and it will only come on once it cools down
Jun 16, 2009 | Heating & Cooling
Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
May 02, 2009 | Goodman CLQ36AR49 Air Conditioner
Our central air conditioning unit is out. The outside unit makes a straining noise but the fan does not turn. I can manually turn the fan blades.
Sounds like a start run capacitor. The motor may be bad too. The capacitor will look bloated if it is bad. There may be other reasons for these parts to fail. So please call a licensed technician for professional help.
Jun 17, 2008 | Heating & Cooling
MY AIR CONDITION ONLY PUT OUT WARM AIR EVERYTHING SEEMS TO BE OK FILTER TURNS ON OK BUT THE OUTSIDE UNIT HUMS BUT DOES NOT FAN
Sounds like a bad start run capacitor. The exhaust fan motor may be bad too. Be careful, this unit delivers 220volts of electricity.
Jun 17, 2008 | Goodman Heating & Cooling
Blower fan keeps shutting on/off,
Your blower fan turning on and off shows your thermostat is working. I am willing to bet you have the fan in the automatic condition. Check for a sticking contactor at the outside unit.
May 31, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
