Question about Kenmore 54501 Dehumidifier
Need a replacement hose - Kenmore 54501 Dehumidifier
Hose is connected to dispose water but bucket fills up
First check that the opening from bucket to hose is clear of obstructions. If you used a washing machine hose and the filter screen is still in the end of the hose, then replace the screen with an ordinary hose gasket.
A gel-like growth can develop in the drain hose. Drain the bucket. Remove the hose and connect it to an outdoor faucet to flush the hose. Reconnect the hose using an ordinary hose gasket.
Oct 05, 2011 | Kenmore 54501 Dehumidifier
I have a kenmore dehumidifier model # 129-25803. I have no manual and it is collecting water, but not into the tank, but through a hose tucked in behind the tank and it is running everywhere. how do I...
You will need to disconnect the hose and replace it with a screw on cap that came with the unit. With that in place, the water will be diverted into the bucket. If you are missing the cap, you can probably find a replacement at Sears Parts Direct.Be sure you have the correct model number when searching Sears Parts Direct or before calling them.
I hope this helped you. Thanks for choosing FixYa.
Jul 23, 2011 | Kenmore Dehumidifiers
NEED THE RUBBER PIECE FOR WATER DRANIAGE; A PLASTIC CONNECTER TO THE SCREW ON WATER EXIT HOSE FITS INTO A SOFT RUBBER INLET PORT; THE SOFT RUBBER INLET COVER HAS MELTED. I NEED A REPLACEMENT PART
I will advice you check ebay.com to search for the replacement part and order for it or you can check any electronics sales shop to get the replacement part.
Take care.
Aug 24, 2010 | Comfort-Aire BHD-501 Dehumidifier
How do you hook it up to a floor drain?
With most portable dehumidifiers use a bucket to catch the condensate. Then the bucket is full the dehumidifier stops, then you need to empty it and replace the bucket to get the dehumidifier to start working again.
To make this unit run continually, the bucket can be modified so a garden hose can be attached and the hose can be feed into a floor drain. To do this look at the bottom of the bucket, there should be a hose connector where you can attach a standard garden hose. You will need to drill out the center of the hose connector with a 1/4" drill bit. Then you can attach the hose to the bucket and the other end into the floor drain.
Jul 01, 2010 | Whirlpool AD25BBK Dehumidifier
Need manual with exploded diagram
If your model has a condensate (water) reservoir, there should either be a threaded hose fitting located at the bottom of the reservoir that will accept a standard garden hose, once you punch out the plug inside the threaded coupler.
If you do not have a threaded hose coupler on your unit's reservoir, remove the reservoir and look inside the area above it and there should be a small hose fitting that you can attach a standard garden hose to, to allow for constant draining without having to use and empty the condensate reservoir daily, etc.
If you don't have either of these items, you'll need to purchase a new condensate reservoir with a hose drain attachment to allow use of an auxillary drain hose. You'll need to contact Maytag customer service for the correct parts and assistance.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(866)616-2601 U.S.
(800)688-2002 Canada
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | Maytag M7DH45B2A Dehumidifier
Need manual for fedder dehumidifer to hook up drain hose. need to know were drain hose connects.
Pull out the water collection tray. You will see a small pipe (about 1/2" diameter) in the top of the area where the tray came from. This is the "drain" that fills the tray. Connect a hose to this pipe and run the hose to a floor drain if you have one. I used a section from an old garden hose for my unit. There also may be a small opening in the back wall of the dehumidifier to route the hose more aesthetically.
Dennis
Jun 12, 2009 | Fedders A7DH45B2A Dehumidifier
Where to buy drain hose
any plumber supply company will have the hose you need just need to know what size
May 09, 2009 | Bionaire BDQ25 Dehumidifier
Need a part
This appliance has 3-ft drainage hose and a 16-ft pump hose. I searched for a store that carry these hose, unfortunately, none of them sell a part or accessory for the DE500P.
Kindly click this link and verify if they could sell a hose:
http://www.nextag.com/delonghi-de500p/compare-html
Good luck.
May 03, 2009 | DeLonghi DE500P Dehumidifier
Replacement part
Replacement 'plugs' can be purchased from most hardware stores.
Depending upon their organization, it will/should be in the 'outdoor' section with the hoses...or in the small hardware section (with the dehumidifiers.)
As the bucket has the 'male' end of a hose, and the original cap has been misplaced or broken, then you just need to cap it....or in the case of a leak (smokeythecat) just put in a standard hose washer to tighten the seal.
Just tell the associate what you are trying to do, and they hopefully can take you to either of these sections to locate the part.
However, if the above 'leak' is actually caused by a crack in the bucket....then a new bucket is more expensive than you (I) expected....I have just gone to the local dump...where the appliances are sorted out...looked for a dehumifier and liberated the bucket (the sizes are remarkably universal...
....this can/is/has been a location for the above desired cap as well :)
Hope these solutions help you to 'fix-ya' ....please rank.
Oct 23, 2008 | Dehumidifiers
To connect a drain pipe
Find where the leak is coming from. Is it coming from the connection where the tube goes into the dehumidifier or where the garden hose screws on? If it is where the garden hose screws on make sure it is screwed on all the way. If it is you may just need to replace the rubber washer in the garden hose.
Jul 25, 2008 | LG LD65EL Dehumidifier
Kenmore 54501 Dehumidifier Logo
23 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
