Question about Gateway Tablets & eReaders
I cannot rotate the screen's display using the tablet control button
I have a tablet, the rotate control button does not work
  • 2,404 Answers
Try holding down the CTRL, ALT and the up arrow or any of the arrows and see if that does the trick with rotating the screen.
As far as the normal rotate button is concerned, try downloading the drivers for it thru toshibas website. If you have the model number of your laptop I can help you with that.
Posted on May 21, 2009
My nextbook display is upside down,,,the power button and camra is at the bottom
If the auto rotate system is on it will switch the controls so try restarting it and then if it still does that go the the programs settings and see if u can fix it.
Jan 20, 2014 | Nextbook NEXT2 Touch Screen Android Tablet
How to rotate asus tablet webcam display 90 degrees?
turn on the auto rotate screen and if that doesnt go in the top right hand corner there should be a button there, click on it and it says rotate just keep tapping it until it rotates to your desiered position.
Nov 30, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
My iPad has a lock on it beside the battery sign how I can remove it so I can send emails
You probably locked the screen rotation,
to fix this:
  1. Rotate iPad so the display is in the desired orientation.
  2. Double-click the Home button to display recently used apps.
  3. Flick from left to right along the bottom of the screen.
  4. Tap the Screen Rotation Lock button on the bottom left of the screen.
  5. The lock will disappear
Jan 17, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Screen will not rotate only displays horizontal
Option1check if your tablets orientation is locked or what Option 2: do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs -> You will see a screen with android and triangle with exclamation mark -> you will also see 4 lines of writing in blue. -> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected) -> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
Mar 31, 2011 | Samsung Galaxy Tab Tablet PC
The screen stopped rotating. what can I do?
You will have to do a factory reset, which will restore the default settings on your device.
1) With the device powered off, press and hold the Volume Up and Power buttons at the same time.
2) When you see the Samsung logo, release the Power button, but continue to hold Volume Up until the recovery screen appears.
3) Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4) Press Volume Up to continue.
Mar 14, 2011 | Samsung Galaxy Tab Tablet PC
How do you unlock the rotation on an iPad? I've looked it up and I'm told the switch above the volume control turns it off and on, but on my iPad it just turns the volume off and on.
Use the following steps to enable screen rotation lock:
  4. Tap the rotation lock button on the bottom left of the screen.
  5. A padlock will appear in the rotation lock button.
Dec 28, 2010 | Apple iPad (16 GB) WiFi Tablet PC
My HP Compaq tc 4400 tablet screen keeps on flipping with out doing anything
The tablet buttons can be disabled to stop your screen from rotating. Go to Control Panel > Tablet and Pen Settings > Tablet Buttons > select the rotate button and click change > select "None" on the drop down menu.
Feb 22, 2010 | Compaq tc4400 Tablet PC
Screen Won't rotate
you need to change your screen resolution to rotate, make it so that it is taller rather tan wider
Dec 27, 2009 | IBM ThinkPad X41 Tablet PC
How do I enable presentation mode on an XT2 tablet? I am in a meeting connecting a Dell Tablet XT2 to a Panasonic projector via vga cable and trying to use Fn8 to display the laptop screen. The setting...
You could be able to enable presentation mode by pressing the "settings" button on the bootom of your display, next to the power button and the "ctrl" and the rotate button. After you press that, your dell control point manager should pop up and then go to the tablet tab on the left and open it. after that, go to the display tab and you should see an option that allows you to turn your presentation mode on.
Nov 05, 2009 | Dell Latitude XT2 Tablet PC
My monitor display has rotated itself 90 degrees counterclockwise and I do not know how to return it to it's normal position. What do I do to return it to it's normal "Landscape" position?? I have a...
on the front of the toughbook there are 4 small buttons, the 3rd from the left which has a right angle symbol with a double headed arrow in it rotates the screen 90 degrees each time you press it. this is probably how you got it like that in the first place.
Aug 05, 2009 | Panasonic Toughbook-19 Tablet PC
Tablets & eReaders Logo
1,442 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
Ricky Ostrom
Ricky Ostrom
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
