Question about Panasonic PT-60LC14 60" Rear Projection HDTV
Lamp light blicks red but bulb is good - Panasonic PT-60LC14 60" Rear Projection HDTV
2 Suggested Answers
Sparko1
  • 167 Answers
SOURCE: Tv will not click for pic to show, bulb good, just blicks green
This TV has a Service Bulletin on it that indicates you should install a Ballast Kit.
Also replace the Lamp with a Panasonic Lamp / No generic.If you just replace the Lamp only, it will burn out fast without the new Ballast Kit installed first. Call a good TV tech and have him check for this problem first.
Posted on Jul 31, 2009
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Replaced both bulbs with brand-new bulbs. Now all
Verify that the lamp doors are securely closed. The blinking red lights indicate a lamp problem. In this case, both appear to be defective. I doubt that the lamps are the problem. double chack all connections and doors for proper seating. Update this if the problem remains.
Thanks,
Dan
Apr 16, 2010 | Sharp XG-PH50X Multimedia Projector
Recently my wd-52327 said it needed new bulb(steady orange light). i had replaced the bulb 7 months earlier and didn't want to see the light so i reset the lamp timer. well the bulb blew the next time i...
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Nov 21, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Jul 31, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
Timer light is blicking off and on
if the sound is working you need to replace the lamp and reset the lamp use hours.
Jul 07, 2009 | Televison & Video
Need to replaced lamp
The easy way to confirm if it is the bulb. Unplug the power to the TV. Remove 2 screws that keeps the lamp cover in the TV. (see manual on lamp replacement). This is on the left side of the TV. Then remove the 2 screws that hold the lamp unit in. Pull out the lamp unit by the handle and then look at the lamp. If it is broken, you will need to replace the lamp.
Dec 03, 2008 | Hitachi 50VF820 Projection TV
WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Panasonic PT-60LC14 60" Rear Projection HDTV Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
