Question about Husqvarna 22 Hp 46" Deck Yard Tractor
What oil grade do I use in my 20hp huskavarna riding mower
The oil needs changed in my 20 hp huskavarna riding mower. I bought it used and don't know what oil grade
  • 10,865 Answers
Use a good grade of automotive engine oil which is called 10w30 weight.
measure the amount of oil that you drain out so you will know approximately how much new oil to put in. then check your dip stick and adjust to get the exact amount of oil.
Posted on May 21, 2009
Engine won't turn over,just here a clicking sound.This all happened after riding mower for 20 minutes and yhe enginge just shut off.
Posted on Jul 19, 2009
My 2001 craftsman, 20hp lawn mower will not start for flooding the cylinders, what could cause it from putting too much fuel in there
with the newer fuel that we have the needle valves in the carb don't seat anymore replace the needle and seat change the oil if possible add a shut off valve inline to the carb and close it when not in use
Jun 24, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How many hours of use can I expect to get from this mower?
the more you do maint on it the longer you will get oil changes filters shape blades help engine load do you ever take off the top cover and clean the cooling fins?do you climb hills?use it to pull loads arouund the yard?but the 20hp kohler engine has had problems cracking the block on top of the engine my mower has a 22hp kohler with 2236hrs on it starting to get tired
Jun 07, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
I need a manual for the Craftsman Walk behind mower #917.388930. The main thing I need to know is when changing oil what is the capacity? SAE 30 non detergent I assume. Thank you.
No, you do not use non detergent oil. You must use only SAE high quality detergent oil with API service classification SG-SL . Use SAE 30 weight or 5W30 if you use the mower during cool conditions below freezing. I highly recommend you use Synthetic oil in this air cooled engine and change your oil once each year. The oil capacity is 20 ounces. You can see the owner's manual at this link. Just click Manual Location and put in the captcha and click submit. No need to sign in or register. http://www.hammerwall.com/Manuals/Craftsman/Description/917.388930/Craftsman%20Walk%20Behind%20Lawn%20Mower%206%20HP%2021%20Inch%20Rear%20Discharge/L0605486/
Jun 27, 2011 | Craftsman Garden
B&S 20hp craftsman 46" dls3500
When you cleaned the carb did you clean out the metering jet with a needle and blow out. It only takes a tiny spec of dirt to raise hell with these small carbs.
May 29, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I need an owners manual for a Craftsman 20hp Dlt 2000. I can not find the drain plug
Do you see a small yellow cap at the bottom of engine below the oil dipstick. Take the cap off and put a small piece of plastic hose on the pipe and push and turn and out comes the oil.
Apr 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
We have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Apr 12, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Husqvarna 22 Hp 46" Deck Yard Tractor Logo
639 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
