Question about Maytag MSD2454G Side by Side Refrigerator
Freezer and fridge is warm
When this first happened I removed the food and unplugged it. After it sat awhile, I plugged it back in and everything was working perfectly - to my amazement. Then a few days later, the entire thing heated up again. The fan is running and I hear clicking like something wants to kick on to cool, it hums and then shts off. I checked back of the interanl freezer and there is no ice on the coils. At the back of the unit, air is blowing near the compressor with force. Any ideas will be appreciated.
  • jacobs7755 May 21, 2009
    Does the link below reflect the Relay/overload with start capacitor that you speak of or is it something different? I think that you are on to something since if the compressor was bad, then the unit should have never have recooled after it's first failure... is that good thinking on my part or no?
    http://www.repairclinic.com/SSPartDetail...
  • jacobs7755 May 22, 2009
    Thanks for Vic's and Sea Breeze's time. The fridge is a
    MSD23578HEB. When I posted, I didn't see it as a choice and used the other model to post (I am a newbie to this and didn't know how to post without drilling down at the home page - sorry). Nevertheless, the compressor is under its original Maytag 5 year warrenty, so I won't be heart broken to hear that the compressor is the problem. I am sorry for bothering you, but can either of you explain to me how the freezer/fridge can quit cooling, and then after being unplugged and replugged in months later it start working just like brand new, and then after some time (I am not really sure - it was running in my detached garage) it stop cooling again with the fan running and the clicking noises from the back. If the starter switch or the compressor is bad, then I wouldn't have thought that it would have ever cooled. Per this post's advise, I unplugged it last night. I hope to get a few days off work to mess with it this weekend to better determine it's problem and to see if it will cool again once I re-plug it back in in hopes of process of elimination. Can I tell if the relay is bad by smelling it or shaking it? How else can I tell if the compressor is bad? Again I appreciate Sea Breeze's and Vic prompt responses and help. It is nice to know that someone is out there willing to take the time to help a stranger. God bless you both.
  • Maytag Master
  • 4,655 Answers
Sounds like the motor start relay and capacitor both need to be changed. The clicking is the overload cutting off power to compressor because it will not start. It will need a better start capacitor also to get it going again. Keep it unplugged until the parts can be tested and replaced. If not the internal overload may be damaged. I am here to help if you need, Sea Breeze
Posted on May 21, 2009
  • 1 more comment
  • John Tripp
    John Tripp May 21, 2009
    Not trying to make this harder for you, but. before you order you may need to look at the numbers closly. There are four series of models to choose from. Sorry to say that but like every company they made changes as they went along. Here is what my supplier says. Below
    Some appliance models had design changes that were made mid production cycle. Though the entire production year shares the same model number, not all were assembled with the same parts. The series number is used to identify the correct part(s) for your appliance.
    What series is your appliance?
    There are two common methods used to identify the series of an appliance. Both methods involve reading numbers from the model number identification tag.
    Some models have the Series Number explicitly listed on the model identification tag. If your appliance does not have a Series Number that is listed explicitly, then it must be derived from the serial number.
    The first two digits of the Serial Number are generally used to identify the series of your appliance. For example, a Serial Number of 1523427RH would constitute a series number of 15.
    What Part is Correct?
    The correct part for your appliance is the part with the series number that is closest to the series number of your appliance, but is SMALLER than the series number of your appliance.
    Example
    Assume that you have a dryer with a serial number 20548963FG. That means the series of your dryer is "20". Assume two blower wheels are listed for your dryer model and that they have series numbers of 10 and 11 respectively.
    The blower wheel with the closest serial number that is less than the dryer series number of "20" is the blower wheel labled as series "11". That would be the correct blower wheel for that dryer.
  • John Tripp
    Another thing I noticed is the model number above your post and the number inside the link are different. Make sure the correct model is listed. On front of refrigerator and near floor behind the fresh food compartment door or behind the kick plate. Make sure you check winding in compressor before you buy anything. Maytag317 is also correct.
  • John Tripp
    John Tripp May 22, 2009
    Start relay and capacitor or worn out compressor. If I had to replace I would replace them with a 3 in 1 relay and capacitor built together.
    President:
  • 1,136 Answers
Hi, You have a relay or a compressor going bad. You can get a new relay and see if it makes a difference. Most models have a 5year warrnty on compressor if it was bought before January 2008. When you hear it clicking, listen in the back and see if you canhear the noise. If I can assist you in getting the relay, please let me know.
Vic
Vic
Freezer is working,but fridge is warm. Fan in back of fridge will not shut off.
If your fridge is not designed with an automatic de-icing function, then there may be an ice dam blocking the cold air from moving from the freezer to the fridge. I had a fridge once that would get blocked with ice even if the rest of the freezer was ice-free.
Unplug your unit (often shutting off the breaker is easier than digging behind the fridge for the plug).
Pull everything out of the freezer and put it in a box. Cover the box completely with blankets to insulate it so your food doesn't thaw and spoil. Prop open the freezer door and let any ice accumulation melt.
Once everything has thawed out, wipe up the water and plug the unit back in. You should be able to tell after 10 minutes or so whether the fridge is getting cooler or not.
Mar 04, 2015 | Refrigerators
I have a maytag fridge (freezer on bottom) the fridge is not very cold. freezer has started to get ice near the door opening in the last week.
if you see ice near the door the door muat not be closing all the way or the gasket could be ripped,ice will form where warm and cold air are mixing together,did you remove any of the shelves or baskets in the freezer or in the fridge?i've seen people clean out the fridge and the shelves weren't put back in correctly keeping the door open,check that or food packages that might be hitting the door,when the warm air gets in it usually freezes the air ducts,this is why the fridge is warm,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer into the fridge section and then it returns through other air ducts so if warm air is getting in it will freeze up the air ducts,you can try shutting down the machine or unplug it,remove the food from the freezer and with a hair dryer hit the back inside wall of the freezer,blow the air up into the vent holes in the back wall,if you see water dripping down through the slots you have ice up in there,keep blowing the hot air up into the holes until you don't see any more water dripping,if you can remove the ice maker and remove the back inside wall of the freezer would be better.first check the freezer back wall to see if there's any frost or like snow on it,if so you could have a defrost problem,bad jazz board,this is the computer board that's behind your digital controls in the fridge section,bad defrost thermostat or heater,also do you mean the floor of the freezer has ice on it,you could have a blocked drain in the freezer.write back with more info and let me know what you find and hopefully i can help you better.
Sep 05, 2012 | Refrigerators
Frozen solid freezer, warm refrigerator. (model Amana bottom freezer abb1922few) Can see frost on freezer foods and back vents (almost occluded). Just vacuumed wads of dog hair/dust off of front half of...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | Refrigerators
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Fridge is freezing food
I have had the same issue with thick frost/ice at the back of my Fridge and almost called an engineer and considered replacing it.. BUT you don't want to so that: Do this:
1. Take freezer draws out and empty fridge so it is lighter and easier to move Fridge Freezer out
2. Chuck some warm soapy water down the drainage hole in back of fridge to ensure it is not blocked
3. Pull the plug. Leave it off for 5-10 mins.
4. Plug it in, reload her
5. Next morning.. perfect all back to normal
I think the unplugging just resets the thermostat and gets your machine back to life.
Jan 13, 2010 | Hoover Refrigerators
Frost build up behind/inside back freezer panel
I have same problem, it usually happens after someone leaves door open too long or after 4-6 months. I usually place two frozen milk jugs full of water in the upper fridge and tape the upper fridge door closed at night before bed so the kids don't open and let the upper food get warm., Unplug the fridge and open the freezer and remove all drawers (place excess frozen food in freezer in garage) , leaving the freezer open with a towel in the bottom to catch the melting water from the back panels inside and the next morning wipe the fridge bottom clean and plug it back up and replace everything. I hate that I paid so much for this fridge and have to defrost a couple times a year. However found out too late to return back to the store. It seams like it should have a cycle that heats the back plate every so often to warm and evaporate the ice that collects, but I haven't heard or can't find anything on that.
Kimsukie.
Jun 16, 2009 | Samsung RB215LASH
Samsung refrigerator freezer not freezing
-2 although below freezing temperature, is not really enough to keep food really frozen. I am presuming we are talking in Celcuis. You need to set the freezer to a lower setpoint.
Mar 09, 2009 | Samsung RB215LASH
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag MSD2454G Side by Side Refrigerator Logo
378 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
