Question about Carrier Heating & Cooling
Central air conditioner will not turn on at all.
Hi.
My central air unit will not turn on at all. It ran earlier but didn't cool the house off. Now it won't turn on at all and the fan doesn't run either.
Please help. Thanks
Carrier Tech2000SS
  • 1 more comment
  • Zippers May 21, 2009
    My husband doesn't think we have a heat pump. He changed the filter and no breakers are tripped. Can I have another solution please? Thanks
    Inside fan on the furnace runs but the fan on the outside unit doesn't run.
    Thank you very much for your time and solutions. I will call our HVAC man as you suggested. Thanks again! Take Care.
  • 585 Answers
I understand this to be a heat pump. Check your thermostat settings, and the filters. And make sure a breaker isn't tripped.
Posted on May 21, 2009
  • 1 more comment
  • Bruce Volkers
    Bruce Volkers May 21, 2009
    Does neither the inside nor outside fan run?
  • Bruce Volkers
    Perhaps this is all caused by a non-running fan in the outside unit. If the fan fails, the unit (compressor) will run but cool poorly until it overheats and shuts down. If the compressor cools down it may come back on but will overheat again without the fan. If the fan is at fault, you should check to see that it turns freely, and check the capacitors for the fan and also the compressor, as the one(s) for the compressor could be bad as a result. I read also that this unit has a low pressure switch. If some of the refrigerant has leaked out, it would also cause poor cooling and shut down. You need a licensed HVAC tech for that.
  • Frank Bennett Sep 24, 2013
    It is the outside fan I'm refering to
Tip
How to fix problem of Air conditioner doesn't cool
How to troubleshoot and repair the most common problems with your central air conditioner Although some central air conditioner repairs must be handled by a qualified air-conditioning repairperson, you can handle simple repairs and maintenance yourself. Following, you'll find guidance based on the symptoms.
Air conditioner doesn't cool A central air conditioner that runs but doesn't cool may just need to be cleaned. Plan to do this on a relatively warm day. The following are basic guidelines, but always refer to your owner's manual.
1) Before you begin, turn off the power to the unit. There is normally a shut-off or disconnect panel on the house wall next to the outdoor compressor. Also shut off the air conditioner's 240-volt circuit at the main electrical panel.
2) Rake leaves and debris away from the outdoor condenser. Trim any bushes that might block airflow.
3) Unscrew and remove protective grilles and the top cover or grille from the compressor. If the fan is attached to the grille, be careful not to pull any wires loose.
4) Use a soft brush to clean dirt and debris from the fins, and then vacuum the fins with a brush attachment (taking care not to damage the fins).
5) From inside the unit, use a hose and nozzle with a trigger-grip to spray debris from the fins (protect the wiring and motor with plastic sheeting or a large plastic garbage bag). If your owner's manual calls for lubricating the motor, do that now--but don't overlubricate.
6) Reassemble the unit.
7) To test it, turn the thermostat to "Off," reset the power at the disconnect by the compressor and the main panel, and then set the thermostat to turn the unit on. Important note: To avoid straining an air conditioner's compressor, wait at least five minutes between turning it off at the thermostat and turning it back on. Let it run for a few minutes, and then feel the two pipes that connect to the condenser unit on the air handler (slide any insulation back). One should feel warm, the other cool.
on Sep 02, 2010 | Heating & Cooling
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
Central air conditioner doesn't cool
no cooling means outside unit is not operating due to
-no thermostat signal
- condenser dirty need cleaning
- fan motor stucked 90% this the reason of noize
Apr 27, 2009 | Heating & Cooling
Air conditioner won't shut off when temperature reached
suspect a stuck contactor on condenser unit or cooling relay stuck
Jun 14, 2008 | Kenmore 72055 Air Conditioner
My central air never kicks off
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Jun 09, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
3,407 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
