Question about Craftsman Remote Control Wall Mount 5.0 Peak HP Wet/Dry Vac
How to reset remote control on craftsman 5 gal vacum
Where do i place the foam sleeve for 5 gal craftsman wet vac
The foam just is put over the round center beneath the top of vacumn with top off the bucket. Just slide up to top of round assembly and you good to go. If you have the paper bag filter on remove it first.
Aug 31, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
Wet vac wont turn on
That Model of Shop vac often has on/off switch failure.
Dec 02, 2013 | Craftsman 20 gal, 6.5 Peak HP Wet/Dry Vac
B&s engine on mower turned upside down, won't start now.
Take the spark plug out, turn ignition key or pull rope until the engine turns over several times. Let it sit for about 5 or 10 minutes and repeat. Replace the spark plug with a new one. Make sure that your crankcase is not over filled or under filled with oil, and make sure that there is plenty of gasoline in the tank. Make sure that gasoline cap and oil cap are on "securely". Now try to re-start. (The engine may smoke for a while, but it should clear up in a few minutes).
Nov 27, 2013 | Craftsman 16-gal 6.5-peak hp Wet/Dry Vac...
Need filter for craftsman6hp. 16 gal shop vac model 113.177060
They're availabe at Sears and Kmart. Lowes and Home Depot also have filters that will work.
Dec 27, 2012 | Craftsman 17765 Canister Wet/Dry Vacuum
Trying to vacum and it starts to blow
There are two outlets on a shop vac one to blow and the other to vacum.
Dec 13, 2012 | Craftsman 12 gal 5.0 peak hp Wet/Dry Vac -...
Craftsman compressor
They put this under vacuums, relist it in the right place.
Dec 16, 2007 | Porter Cable 7812 Wet/Dry Vacuum
Craftsman Remote Control Wall Mount 5.0 Peak HP Wet/Dry Vac Logo
Top Craftsman Vacuums Experts
downhille
Andrew Taylor
Andrew Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
