Question about Bowflex Treadclimber
Cant find where to plug in wire - Bowflex Treadclimber
What opel spark plugs can i fit on my daewoo lanos 1.6sx
are you saying that daewoo spares do not sell plug wires for daewoo cars ---
go to a daewoo wreckers -junkyard--and get plug wires from them
Aug 17, 2016 | Daewoo Cars & Trucks
My power window plug at the door and body has a wire that is broke off in the plug itself. It has a clip that I cant seem to be able to remove. Suggestions??
Hi,are you saying that you cant remove the block connector,if its that you have removed the block connector but cant get the wire out of the connector,I would sudjest you just cut the old block off and replace it with a new one.all the best.
ps,let me know if this is what you ment.
ps,maybe if there is anough wire on bougth sides you could just cut and join them together with a connector.
Apr 19, 2015 | 2004 Dodge Durango
How to remove wires from sparkplugs of a guick lucerne
USE A SPARK PLUG WIRES BOOT PULLER.THE BOOT PULLER CAN GO TIGHT PLACES WHERE YOUR HANDS CANT REACH.ONCE YOU REMOVE SPARK PLUGS WIRES REPLACE THEM.SOME PLUG WIRES WILL BREAK AWAY FROM THE BOOT WHEN REMOVING SPARK PLUGS WIRES.DONT REMOVE OLD PLUG WIRES IF YOU DONT HAVE NEW SET PLUG WIRES ON HAND.BECAUSE YOU WILL DISABLE VECHICLE.IF COUPLE OLD PLUGS WIRES BREAK WHILE REMOVING THEM YOU WILL BE 2 PLUG WIRES SHORT AND YOU CANT DRIVE VECHICLE THAT WHY HAVE NEW SET OF PLUG WIRES ON HAND.
May 12, 2011 | Buick Lucerne Cars & Trucks
1990 ES 250: i cant take off the top of the engine so i can cha...
You should just need a extention to get at the plugs and a plug wire puller and you should be good no need to disacemble
May 18, 2010 | 1990 Lexus ES 250
I replaced the spark plugs and now it won't start
Did you gap the plugs and replace the spark plug wires exactly the way you removed them? Did you remove any wires from the distributor cap? Make sure Each spark plug wire snaps on, it cant simply float on top of the plug, the wire must be firmly seated on the plug tip.
Mar 09, 2010 | 1995 Ford Aerostar
I cant determine which plug on the wiring harness
The Correct Plug Has a PINK Wire With a Black STRIPE on it
Sep 27, 2009 | 1994 Cadillac Fleetwood
Cant find the towbar electrics plugs for x-type
I assume that the towbar didn't come with a proper wiring kit as, unfortunately there is not a specific connector for the towbar wiring on the x-type, the proper Vehicle Specific Kit plugs into the rear light. There is a power connector with three pins on the left and a grey reverse sensor cut out connector also on the left. but you will either need to use a Vehicle Specific Wiring kit (about £175) or use a bypass relay system.
Aug 30, 2009 | 2006 Jaguar X-Type
I cant see the wires goint to the spark plugs,
they come off the distributor cap to the plugs
Aug 21, 2009 | 2008 Mitsubishi Lancer
Cant get fax to work
You should be able to use it just like a telephone. Make sure you have the phone wire plugged into the in jack and the telephone unit wire plugged into the out wire. If it's plugged in backwards, it won't work. Put your papers in, press the number you want and press start or send.
Jan 03, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Bowflex Treadclimber Logo
14 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
