Question about Vehicle Parts & Accessories
How to remove lock - Vehicle Parts & Accessories
HOW TO REMOVE THE KNOB ON A KEYED LOCK SET
Posted on Jan 20, 2014
How do i tear apart my steering column in my 84 dodge pickup so i can change my ignition switch?
  1. NON TILT WHEEL
  2. Remove the steering wheel.
  3. Remove the turn signal switch.
  4. Unfasten the two screws that release the buzzer switch (if equipped), then remove the switch.
Fig. Fig. 2: Removing the ignition buzzer
  1. Remove the retaining screw and lift the ignition lock cylinder lamp out of the way.
Fig. Fig. 3: Ignition key lamp
  1. Remove the bearing housing.
  2. Detach the coil spring.
  3. Remove the lock plate from the shaft.
Fig. Fig. 4: Lock lever plate removal
  1. Unfasten the 2 retaining screws and lift the lock lever guide plate to expose the lock cylinder release hole.
  2. Insert the key and place the lock cylinder in the LOCK position. Remove the key.
  3. Insert a thin punch into the lock cylinder release hole and push inward to release the spring-loaded lock retainer. At the same time, pull the lock cylinder out of the column.
Fig. Fig. 5: Depress the lock plate which will expose the lock cylinder release hole
  1. Remove the 3 retaining screws and lift out the ignition switch.
To install:
  1. Position the ignition switch in the center detent position (OFF).
  2. Place the shift lever in PARK.
  3. Feed the wires down through the space between the housing and jacket. Position the switch in the housing and install the 3 retaining screws.
Fig. Fig. 6: Lock levers and spring assembly installed
  1. Place the lock cylinder in the LOCK position, and press it into place in the column. It will snap into position.
  2. The remainder of assembly is the reverse of disassembly.
Aug 14, 2011 | 1984 Dodge Pickup 4WD
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
How do you replace the ignition key switch for a '96 chevy diesel 1 ton 4wd pickup truck?
Ignition Switch Removal & Installation To Remove:
  1. Remove the steering column trim covers.
  2. Remove the wire harness from the retainers as needed.
  3. Slide the 2 connectors of the multifunction switch assembly out from the bulk head connector.
  4. Detach the key alarm connector from the lock assembly.
  5. Remove the ignition switch mounting screws and the ignition switch from the steering column.
Ignition switch removal/installation gm-08-00-1141.gif
To Install:
  1. Install the ignition switch on the lock module.
    • Tighten the screws to 42 lb in (4.7 Nm).
  2. Install the key alarm connector on the lock module.
  3. Slide the turn signal and multifunction switch connectors into the bulkhead connector.
  4. Install the harness in the original retainers.
  5. Install the steering column trim covers.
Ignition Lock Cylinder Removal & Installation To Remove:
  1. Disconnect the negative cable from the battery.
  2. Disable the supplemental inflatable restraint (SIR) system.
  3. Remove the steering column trim covers.
  4. Turn the ignition lock cylinder to the run position.
  5. Using an awl with a bent tip, insert the tip into the access hole of the ignition lock cylinder.
  6. Turn the lock cylinder to start and push down and hold the lock cylinder retaining pin.
  7. Release the lock cylinder to the run position and withdraw the cylinder from the steering column.
To Install:
  1. Align the slot in the steering column to the tab on the lock cylinder and install the lock cylinder until it locks in place.
  2. Install the steering column trim covers
  3. Connect the negative cable to the battery
  4. Check for correct operation
Oct 08, 2010 | Chevrolet 3500 Cars & Trucks
My 1995 f-150 ford needs a new key ingintion lock, i can start the truck without the key. is this a easy fix?
To remove the ignition lock:
CAUTION
You must remove the steering wheel when replacing the ignition lock. On vehicles with a Supplemental Inflatable Restraint (SIR) system, you must temporarily disable the SIR system and remove the inflator module when removing the steering wheel. Leaving the SIR system on could result in deployment of the air bag and possible personal injury.
  • Disconnect the negative battery cable, and remove the steering wheel.
  • Remove the bumper and the carrier snapring retainer from the steering shaft.
  • Use a lock plate compressor screw tool to install the lock plate compressor screw in the upper steering shaft. To keep the shaft from telescoping, tighten it to 40 inch lbs.
  • Using the lock plate compressor tool, install on the upper steering shaft, tighten it to depress the shaft lock. Remove the shaft lock retainer, the compressor tool and the steering shaft lock.
  • Remove the turn signal canceling cam assembly. Put the turn signal switch in the "N" position and remove the upper bearing spring.
  • Position the turn signal switch so the mounting screws can be removed through the holes in the switch and remove the turn signal lever.
  • Remove the turn signal switch-to-steering column screws and lift the turn signal switch. Remove the wire protector and disconnect the turn signal switch connector.
  • Use a terminal remover tool to disconnect the buzzer switch wires from the turn signal switch connector. Remove the buzzer switch assembly with needle-nose pliers.
  • Place the lock cylinder in the ACC position, then remove the lock retaining screw and the lock cylinder set.
  • To install the new cylinder lock, reverse the removal procedures.
  • Tighten the lock retaining screw to 22 inch lbs., the turn signal switch screws to 59 inch lbs. and turn the turn signal lever screw to 53 inch lbs.
  • As part of the final replacement procedures, check the operation of the switches and the steering column.
Aug 10, 2010 | 1995 Ford F150 Styleside Regular Cab
My ignition is locked and will not turn. i am trying to replace the ignition but am having trouble figuring out how to remove it. do u have to take the steering wheel off and if so wont that mess up the...
You have to remove the steering wheel with a puller,and the lock plate ,with a lock plate remover tool,and the cancel for the turn signals,and then the turn signal switch,then you remove a screw on the right side about 2 o clock position,and the lock and key will slide out.
Jul 12, 2010 | 1997 Chevrolet Blazer
Where can i find a web page that can show me step by step Ignition Lock Cylinder Removal for gmc yukon 1996
When carrying a live inflator module, make sure that the bag and trim cover are pointed away from you. Never carry the inflator module by the wires or connector on the underside of the module. In case of accidental deployment, the bag will then deploy with minimal chance of injury.
When placing a live inflator module on a bench or other surface, always face the bag and trim cover up, away from the surface.
  1. Disconnect the negative battery cable and disable the SIR system.
  2. Remove the upper and lower shroud, air bag module and the steering column.
Exploded view of the removal of the SIR coil assembly
  1. Remove the retaining ring, SIR coil assembly, wave washer.
  2. Remove the shaft lock retaining ring using tool J 23653-SIR or its equivalent to push down the shaft lock shield assembly. Discard the ring.
  3. Remove the shaft lock shield and turn signal cancel cam assembly.
  4. Remove the park lock cable assembly from the lock module assembly.
  5. Remove the key alarm switch, if equipped by gently prying the alarm switch retaining clip with a small pry tool. Rotate the alarm switch 1/4 in. turn and remove.
  6. Remove the two tapping screws and the ignition key and alarm assembly. Let the switch hang freely.
CAUTION The lock assembly is under slight spring tension. Hold the lock bolt in place while removing the lock module assembly.
  1. Remove the three pan head tapping screws and the lock module assembly.
  2. Remove the backing plate from the module.
Mark the two sector gears at the OFF-LOCK position to ensure proper reassembly
  1. Remove the sector gears.
  2. Remove the positioning tab on the end of the lock cylinder using an 1/8 in. burring tool. Remove all burrs from the lock module and cylinder assembly.
  3. Push on the locking tab of the lock cylinder from inside the lock module assembly and remove the lock cylinder.
To install:
  1. Align the marks on the sector gears and install the gears and the backing plate to the lock module assembly.
  2. Install the lock cylinder set and ensure that the lock module assembly is in the OFF-LOCK position.
  3. Install the key in the lock cylinder and ensure that it is in the OFF-LOCK position.
  4. Line up the locking tab with the slots in the lock module assembly and push the cylinder into position.
  5. Rotate the lock cylinder to the ACC position. The alignment arrows on the sector gears should be pointing towards each other.
  6. Rotate the lock cylinder to the LOCK position. Push the lock bolt in until it is flush and align the lock module assembly with the head assembly and install the lock module assembly.
  7. Install the three pan head screws and tighten to 53 inch. lbs. (6 Nm).
  8. Install the ignition and key alarm switch assembly and the fasteners. Tighten the fasteners to 12 inch. lbs. (1 Nm).
  9. Install the key alarm switch. Make sure the retaining clip is parallel to the lock cylinder. Rotate the alarm switch 1/4 in. turn until locked in place.
  10. Lubricate the lower brass surface of the turn signal cancel cam assembly with synthetic grease and install the assembly.
  11. Align the inner block tooth of the lock plate to block tooth of race and upper shaft assembly and install the assembly.
  12. Install a new shaft lock ring using tool J 23653-SIR and ensure the ring is firmly seated in the groove on the shaft.
  13. Install the center race and upper shaft assembly.
  14. Place the ignition switch to the lock assembly and ensure the coil is centered.
  15. Install the wave washer and the SIR coil assembly.
  16. Install the retaining ring and route the coil wire along the steering column.
  17. Install the wire harness straps to the steering column harness.
  18. Install the park lock cable assembly with the transmission in Park and the ignition switch in the OFF-LOCK position.
  19. Install the upper and lower covers, lock cylinder set and tilt lever (if equipped).
  20. Install the steering column and enable the SIR system. Connect the negative battery cable.
Exploded view of the sector gear timing position (OFF-LOCK)
Jun 02, 2010 | 1996 GMC Yukon
Door lock assembly
Toyota Corolla 1988-1997 Repair Guide Door Locks - REMOVAL & INSTALLATION
(see Figure 1)
  1. Disconnect the negative battery cable.
  2. Remove the door panel and watershield. Remove the service hole cover.
  3. Disconnect the door outside opening linkage. Remove the two mounting bolts and remove the door handle if in need of replacement.
Fig. 1: Power door lock control system component locations
  1. Disconnect the lock cylinder control linkage.
  2. Remove the lock knob and the child protector lock lever knob.
  3. Remove the lock assembly retaining screws and remove the door lock. If equipped with power locks, disconnect the electrical harness.
  4. To remove the lock cylinder, remove the lock cylinder retaining clip and pull the cylinder from the door.
To install:
  1. Coat all the door lock sliding surfaces with multi-purpose grease.
  2. Install the outside handle with the two retaining bolts, if removed.
  3. Install the door lock solenoid linkage to the door lock.
  4. Connect the link to the outside handle.
  5. Install the lock knob and the child protector lock lever knob.
  6. Install the door opening control link tighten the mounting bolts to 48 inch lbs. (5 Nm).
  7. Install the door lock cylinder control linkage.
  8. Install the door panel and watershield.
  9. Reconnect the negative battery cable.
Hope help with this; remember rated this post and thank you for using Fixya.
May 20, 2010 | 1991 Toyota Corolla
How do you remove the ignition lock cylinder on a 1991 chevy cavalier
The ignition switch removal and installation procedure is given in , under steering, because the steering wheel must be removed for access to the ignition switch.
CAUTION
The steering wheel is splined to the steering column and held in place by a nut. Courtesy of General Motors Corporation - Service Operations.
Hope this helps (remember rated and comment this).
Mar 22, 2010 | 1991 Chevrolet Cavalier
I have a 2002 Lincoln ls . How do I replace the abs speed sensor? Right front tire?
you have one on the inside of each wheel.
SECTION 206-09A: Anti-Lock Control 2002 Lincoln LS Workshop Manual
REMOVAL AND INSTALLATION Front Wheel Speed Sensor
Material Item Specification RTV Silicone Sealant
FSTZ-19G204-AB (Canada CXC-114A) NAVSTR Sealer
Removal and Installation
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Position the inner splash shield aside.
    1. Remove the pin-type retainers.
  1. Disconnect the anti-lock brake sensor electrical connector.
  1. Remove the anti-lock brake sensor harness from the brake hose clips.
  1. Remove the anti-lock brake sensor.
    1. Remove the anti-lock brake sensor clip.
  1. NOTE: Make sure the anti-lock brake sensor is fully seated before installation of the new clip.
    To install, reverse the removal procedure.
    • Apply a 2.5 mm (0.1 in) bead of silicone sealant to the outside diameter of the anti-lock brake sensor.
Rear Wheel Speed Sensor Removal and Installation
  1. Disconnect the rear anti-lock brake sensor electrical connector.
  1. Remove the rear anti-lock brake sensor harness from the control arm clips.
  1. NOTE: Clean off dirt and foreign material that may have collected around the rear anti-lock brake sensor before removal.
    Remove the rear anti-lock brake sensor.
    1. Remove the anti-lock brake sensor bolt.
  1. To install, reverse the removal procedure.
Feb 24, 2010 | 2001 Lincoln LS
Replace ignition tumbler
STEP BY STEP Please Remember to Rate Me Thank You RejakWilson
WARNING: On vehicles equipped with Airbags, disable airbag system prior to performing service procedures.
  1. Disconnect battery ground cable.
  2. Remove steering wheel as outlined under STEERING WHEEL procedure.
  3. Using a screwdriver, pry cover from housing.
  4. Using lock plate compressing No. J-23653 or equivalent, compress lock plate, and pry snap ring from groove on shaft, Fig. 5. Slowly release lock plate compressing tool, then remove tool and lock plate from shaft end.
  5. Slide canceling cam and upper bearing preload spring from end of shaft.
  6. Remove turn signal (multi-function) lever.
  7. Remove hazard warning knob retaining screw, button, spring and knob.
  8. Remove pivot arm.
  9. Wrap upper part of electrical connector with tape to prevent snagging of wires during switch removal.
  10. Remove switch retaining screws and pull switch up from column, guiding wire harness through column.
  11. Reverse procedure to install.
  1. Remove turn signal switch as outlined under TURN SIGNAL SWITCH.
  2. Remove buzzer switch and spring clip. On 1990-92 models, ignition key must be removed from lock to remove buzzer switch. On 1991-92 models, switch and spring clip are one assembly.
  3. Turn lock cylinder to Run position on 1989 models or Lock position on 1990-92 models, then remove lock cylinder retaining screw and the lock cylinder.
  4. To install, rotate lock cylinder to the stop while holding housing. Align cylinder key with keyway in housing, then push lock cylinder into housing until fully seated. Lock cylinder must be in Run position to install buzzer switch.
  5. Install lock cylinder retaining screw, then the buzzer switch, turn signal switch and steering wheel.
Aug 30, 2008 | 1989 Chevrolet Celebrity
Vehicle Parts & Accessories Logo
530 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
