Question about KitchenAid Architect Series II KUDC20CVSS Full Console Dishwasher - Stainless Steel
Blinking lightds lights are blinking
I repaired a wire in my head lights now. My high beam indicator stays on for both high & low the wire I fixed was just a single wire
wire in the wrong place, you have the replacement wire in the wrong place and have both beams working together.
May 05, 2015 | Cars & Trucks
Dash lights dont work
check your fusses
Aug 14, 2014 | Cars & Trucks
My intrior ,hazard lights aren't working.i checked fuse for hazard lightd it is ok. and my radio light isn't on. this is 2003 kia Sedona. I have no owners manual
check all fuses in the right kick panel. if you have the cover the inside gives you a diagram of what fuse is what. check for illum fuse, iod and audio.
Oct 30, 2013 | 2003 Kia Sedona
Model MDBTT60AW quit working - control panel has no effect. Lights will sometimes come on - all of them at once, but the buttons do nothing. Thanks for any help I can get. David Meek
The front touchpad panel uses a ribbon cable to connect the buttons and lightd to the electronic control unit. This ribbon cable tends to corrode atvthevpointvwhere it passes through the door to the control unit. You will see a brownish rust on the ribbon cable. A new control panel appears to e around $135.
Jan 23, 2011 | Maytag Dishwashers
I cannot get my 2002 imprezza parking lightd to
there is a switch on the steering column on most Subarus that turns the parking lights on. This switch is easily bumped while cleaning the dash area. I would almost put money on this being the problem.
Apr 11, 2010 | 1993 Subaru Legacy
Windows wont go up
okay now. make sure you have new batteries inthe remotes..saves hassle later.put key in drivers door hold key over to unlock car(.hold over for 30 secs) ,then take key out..the windows may go down all the way then hold ing key over for 30 secs, lock the car the windows will go all the way up.if they bounce bach try again but slowly...you have just reset alarm/locking/windows.the trunk light is on a timer with the interior lightd when you start the car the interior light dim slowly etc...
Mar 07, 2010 | 2001 Audi A6
Xbox360 2 red lightd
if you have a cooling core on it then you can't do too much more but if you don't then go buy one and put it on it that will normally fix it.
Jun 30, 2009 | Microsoft Xbox 360 Console
Brake light not working
Check fuses I'll bet you have a fuse blown
Apr 29, 2009 | 1997 Chevrolet Blazer
Ford escort lights
First question, have you actually tested the bulbs out of the car? If not, its worth just testing them in another car or with test wires onto the battery...
Check also the four headlamp fuses. There should be one for each headlamp for each beam setting.
If you know they are good, your suspect is probably the stalk controlling the lights, or the headlamp relay. The stalks are a bit prone on these.
Jan 04, 2009 | 1996 Ford Escort 4 Door
KitchenAid Architect Series II KUDC20CVSS Full Console Dishwasher - Stainless Steel Logo
21 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
