Question about LG Shine KE970 Cellular Phone
Lg Glass/mirror replacement
So do we have to break the glass manually? or is there a special way to replace the glass/mirror without breaking it?maybe like unscrewing a speical bolt?
  • brysgirl Mar 16, 2009
    My glass/ mirror on my phone needs replaced as well. Not sure what steps I should take to fix it.
  • 452 Answers
For screen replacement the best solution is to consult hardware vendor.Doing it urself could damage intrernal parts of the phone
Posted on Oct 22, 2007
It is just glued in so take a sharp knife like a craft knife all around the edge and it will just pull off.
Posted on Nov 27, 2007
How do I replace the glass on the right side exterior mirror of a 2008 Hyundai Tucson
The glass is just glued on, break the old glass away (goggles are a must here) and the clean off the adhesive and then place the new mirror glass element and press hard to attach it.
Feb 17, 2017 | 2008 Hyundai Tucson
How do I remove the broken mirror glass on my car in order to replace it, so I don't have to replace the whole assembly as pictured below.
the mirror glass snaps in and out very easily. but it also breaks very easily if your not sure put the whole mirror on its not that hard.
Jun 10, 2015 | Cars & Trucks
Replace drivers side mirror 2001 chevy tahoe,mirror only
To just replace the mirror glass there are a few different styles, but they all pull off. I suggest you wear gloves and glasses. Get a grip behing the glass and pull out. You should see a round circular bracket in the center. The new mirror just snaps into the bracket. Center new mirror and push evenly in the center of glass until it snaps into place. Dont push in by holding the edges, you'll break it. If you don't see the circle or it comes off with the glass it was too damaged for just glass. Power or manual mirros differ inside, but the mirror replacement is the same. If you mean the entire mirror only, remove door panel. Lower window, remove electrical connector if power, remove 3 bolts attaching mirror to door. Remove.
Jan 27, 2011 | 2001 Chevrolet Tahoe
Need to replace the LH mirror glass on and 08 tahoe, current one is broken. I have the part and just need to know how to pry the old one off without breaking anything
id heat it with a hair dry for a few mins get the old glue kinda sticky the pry it off but somtimes u have to just break the glass all off
Oct 17, 2009 | 2008 Chevrolet Tahoe
Need to replace driver side mirror of an 2008 ford fusion, but wanted to know if i could just replace the glass instead of the whole mirror? the glass is the only thing that is actually broke.
You can buy stick on replacement mirror glass for most models in good motor accessory shops.These just stick on to the existing glass if there is enough left to stick it to.
If not the dealer will supply the glass seperately but its a little tricky to fit and might be well worth letting them fit it too as it is very easy to break while fitting.
Sep 18, 2009 | 2008 Ford Fusion
I broke my passanger side mirror. I bought new
Jul 15, 2009 | 2008 Hyundai Elantra
Passenger Side Mirror Glass Discoloring on Bottom Edge
Hi,welcome to fix ya. this is pretty easy heres how click here be sure to heat the glass with a blow dryer first to soften the tabs on the glass . If there is anything else I can help you with let me know .
Apr 01, 2009 | 2004 Acura TL
Passenger side mirror
If you need to replace the entire mirror - it's a little involved. First you need to take the upper extension panel off from behind the mirror (black triangle) - just pull it of starting at the top. It will snap back on later. Next - remove the different screws holding the door panel in place (not the ones behind the mirror yet!) One is under the handle (pull it out and pull out the filler panel - small plastic thing that has a hole to pry it out). Then take off the rear red light - also pops off - and remove that screw. Finally - pick up the rubber filler where your fingers pull the door shut and remove these torx bolts.
Now is the tricky part. Snapp off the entire interior panel. It will pop off - but very difficult. It will sound like it is breaking! Start at the outer bottom corner - and use a door panel remover tool - check Amazon or E-bay - to keep from breaking things. Pull it out from all around the bottom and sides and then lift it up over the door lock. It good to have a friend help here. The panel will still be held on by a cable - that is your door release - leave it alone and let the panel hang by it (or better, put a box under it to rest on).
Now...remove the three bolts holding the mirror on - have a friend help hold the mirror while you do this or it will scratch your new car! Since the inner panel is off - you can also disonnect the mirror plus and remove it. It sounds silly - but the only reason to remove the door panel is to unplug it!
Get you new mirror and reverse the steps.
If you are just replacing the glass (non-heated) - get a replacement from the dealer. Adjust the mirror all the way to the inside and reach behind and pop it off. CAREFUL - put tape over the entire glass as it will likely break even more! Remove your connectors if heated - and replace (and reconnect) with your new glass. It just pops back on!
Replacing glass is easy - just be careful of cheap imitations on e-abay). And never use cheap flat glass on the passenger side! The DOT has special requirements for mirror glass - buy it from or your local dealer.
Oct 30, 2008 | 2008 Chevrolet Impala
LG Shine
So do we have to break the glass manually? or is there a spcial way to remove the glass to replace it?
Aug 19, 2007 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
838 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
